Go to Post I predict the champion drive teams at each event of the 2011 season will consist of vertebrates. - Taylor [more]
Unread 28-01-2014, 21:02
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
pic: 4242 2014 CAD 1
Unread 28-01-2014, 21:03
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: pic: 4242 2014 CAD 1
I like it, looks simple and reliable. Someone will need to be the first leg of every alliance. Could you post some brief robot functions? I'm assuming it can score in the low goal if need be but can it pick up off of the ground? How is its catching ability?
Nice render by the way, looks classy.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 28-01-2014, 21:51
FRC #4242
Thanks! Simple is what we were going for. Some ideas/functions:
Autonomous: Drive to low goal, deposit the ball, reverse to starting position (for better field position).
Teleop: The idea is to be easily fed from the human player and not have to pickup from the floor. If necessary, we can do floor pickup, but we'd have to trap the ball first. If we're doing our job, this shouldn't happen. The orthogonal wheel configuration allows us to move the ball in all directions when on the robot. It's not completely assembled so we haven't tried catching yet, but hopefully when the up/down wheels are spinning, it should make catching easier. We'll see...
It's a 4 CIM kitbot but we geared down to 10.71:1. We might swap out the tough boxes for 3CIM4U's.
Questions, comments, and criticisms are welcome! Tell me something I haven't thought of yet!
Unread 28-01-2014, 22:15
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
If your plan is to be on the first leg, then strategically you may think about building a high goal blocker. You look like you have room/weight for it and it would make you incredibly desirable.
Unread 28-01-2014, 22:36
FRC #4242
We thought about a high goal blocker but couldn't figure out how build one that would collapse to maintain our low CG and wouldn't deflect outside the 6" column while deployed when hit with a ball. We thought double scissor lift would work maybe. If you have any ideas, I'd appreciate it. We thought I'd be too easy to counter in teleop, so it would only be effective in autonomous. Maybe it would work if you placed the bot in the middle of the goalie zone and used the slider on the driver station I/O to tell the robot how far left or right to move to be in the way of a shooter. Anyway, just a thought.
Unread 29-01-2014, 00:40
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
have a 4-5" tube stick up to about 5' (max height). have another tube slide inside that which is a good fit (you could use small platic plates to make sure it slides nicely and use a pully system to deploy it to however high you want... (you can learn from the pink team)
If you'd like to pursue this further feel free to ask any questions!
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 29-01-2014, 09:11
Erobot's Avatar
Erobot Erobot is offline
THE ROBOT
AKA: Elisha Blue
FRC #0701 (ROBOVIKES)
Team Role: CAD
Erobot is an unknown quantity at this point
Cool Re: pic: 4242 2014 CAD 1
Yes, Your type of robot will be very useful. Our team will be look for robots like yours.
Unread 29-01-2014, 09:21
Ryan Caldwell's Avatar
Ryan Caldwell Ryan Caldwell is offline
217 Alum, 2851 Founder, 469 Mentor
FRC #0469
Ryan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant future
Send a message via AIM to Ryan Caldwell
If you have the weight to play with, you may want to have your back wall be 60" tall to block all the low to the ground shooters.
Insane and Insight are just about the same thing if you squint and turn your head ever so slightly
Unread 29-01-2014, 13:39
FRC #4242
Good idea. Might as well add some lightweight height to it. Maybe to assist with catching/loading. Pool noodles may make an appearance...
Unread 29-01-2014, 15:44
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I'm definitely hoping at least a few teams build robots like this at the regionals we attend. A dedicated inbounder will be really useful to a variety of alliances. Even if you're not tall you may still be able to play effective defense if you are smart about it.
Unread 29-01-2014, 16:02
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
While you are at it, make a 20" extension that swings up around a pivot right at the 59"-60" mark. That way you are even more of a nuisance to any shooter while nearby.
(artwork courtesy of yours truly )
Unread 29-01-2014, 18:41
FRC #4242
I like the artwork! We're not sure how high we would go with a blocker but this seems like a good idea at any height. I'm a little unclear on the rules on shooting. Can the ball be shot from any zone?
Unread 29-01-2014, 18:47
I am Dave! Yognaut
AKA: Brian Bray
A robot shooting into their goal must be between that goal and the truss
(so no full court scoring) but Half-court scoring is legal
EDIT:
Originally Posted by Rule 3.1.4
A BALL is considered SCORED in an ALLIANCE’S GOAL if
a ROBOT causes one (1) of their ALLIANCE’S BALLS to cross completely and remain completely through the opening(s) of one (1) of their ALLIANCE’S GOALS without intervening human contact,
the ALLIANCE ROBOT last in contact with the BALL was entirely between the TRUSS and their ALLIANCE’S HIGH GOALS, and
the BALL is not in contact with any ROBOT from that ALLIANCE.
Unread 29-01-2014, 20:14
AKA: Cam Pizzo
Any sort of Goalie attachment would be a good idea. Teams like versatility, even if that versatility is never used. Just adding something that is different will make your bot look better to everyone else.
It's also my opinion that people are discounting how good a goalie could be in teleop. The further away a robot shoots, the more time a drive has to react to that shot to block it. Even if another robot comes to block you from blocking the shot, that is taking one robot out of the opposing alliances strategy.
Maybe this is just wishful thinking but I bet that there will be a few matches this year in which a goalie locks down the offense completely. You only have to block one ball at a time and you have a pretty good idea of where that shot is going if you watch the shooting bot. 6" is small but very workable.
Unread 29-01-2014, 22:37
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
The blocking mechanism cannot exceed a 6 inch diameter per R3
R3
The ROBOT must satisfy the following size constraints:
the total length of the FRAME PERIMETER sides may not exceed 112 in. (see Figure 4-1 for examples),
a ROBOT may not extend more than 20 in. beyond the FRAME PERIMETER (see Figure 4-2 for examples) (see G24), and
the ROBOT height may not exceed 60 in., except as allowed by G23.
Any extension above 60 in. may not exceed a 6 in. diameter vertical cylinder (see Figure 4-3 and Figure 4-4 for examples), per G23.
2015 GKC Engineering Inspiration
2015 Colorado Winners
