Go to Post Are you confused yet? - Andy Grady [more]
Unread 28-01-2014, 23:26
RoboNerd01's Avatar
RoboNerd01 RoboNerd01 is offline
Super User
AKA: Austin Rowe
FRC #3604 (Goon Squad)
RoboNerd01 is an unknown quantity at this point
Angry Using I2C to communicate with arduino in LabVIEW.
I have been trying to use the WPI I2C library to communicate with my arduino mega 2560 for a LCD display for a while now... But the problem is that LabVIEW tries to verify that the "sensor" is there and wont send ANYTHING to it until it receives a response from the "sensor". Has anyone ever used I2C for anything close to this, or at all? Or is there a better and easier way to do communications? I searched everywhere but could not find ANYTHING on this.
And I'm curious if it is legal to use an Ethernet shield of our robot.
Thanks.
Unread 29-01-2014, 03:35
gvbravo gvbravo is offline
FRC #5089
gvbravo is an unknown quantity at this point
Re: Using I2C to communicate with arduino in LabVIEW.
Two things to consider. Are you using a 7 bit or 8 bit address and do you have the arduino board set up as a slave?
If you have an oscilloscope that would help too.
Unread 29-01-2014, 10:08
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
I've tried...
http://www.chiefdelphi.com/forums/sh...d.php?t=120173 You could try post #4 from this thread.
Best bet is to use the serial port, it has proven to be better for me. I suspect this is because I2C is so heavily geared towards reading sensors while the serial VI's were made more for general 2 way communication use. I would look into sending things in strings to the arduino storing them then sending them to the display from the arduino.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 29-01-2014, 10:33
steinra's Avatar
steinra steinra is offline
(KG7KEO)
AKA: Randy Steiner
FRC #5461 (V.E.R.N.)
steinra is on a distinguished road
An Ethernet shield would work as well for communications. But I am interested in seeing what you find out on I2C as well. We were looking at possibly using this as well as a communications method.
Randy
Randy Steiner
2014-2015 FIRST Team 5461 - Coach
2011-2014 FIRST Team 4106 - Head Mentor
2007-2011 FIRST Team 1891 - Mentor
