Re: LabView code of other teams ?
That sounds almost like the code to control the cylinder is only running when the compressor is not. Can you show us the relevant parts of your program?
http://imgur.com/yWLShcp http://imgur.com/JcrDTcO&yWLShcp&NfAFJ3K&O8KQNNz#0 (green wires come from two different buttons) These are the codes releated to our solenoids in our begin and teleop vi. To try in a different way, we first ran the compressor and filled the air tanks and then wired a solenoid and run the program. It still does the same thing. Although the pressure switch or compressor aren't wired, we can't extend the pistons below nearly 100 psi. Is it normal? |
Or maybe whatever you have the cylinder connected to just requires that much force in order to move. What is the mechanism you're trying to activate with the cylinder? |
We solved our problems with solenoids. Thanks for your help. I guess I was lack of some essential information about solenoid. First we changed the code and then checked our wiring. We found out that our solenoid breakout is not fed by 24v on pdb and fixed it by wiring it to C and NC outs. All of our solenoids are 24v, we missed that detail. We can finally drive our robot, shift and control other pneumatic systems properly. Now, the only thing that was left is vision processing in autonomous. We looked over the example code and tried to understand it. We could customize our dashboard by the example code. However, we still don't have any idea how to link the example code to our robot actions in autonomous mode. I know this thread is going far from its title and hope that it's not a problem. Do you have any simple and clear resources about using vision processing code in auto mode? |
