Go to Post Welcome to the imperfect world of design! - Joe Johnson [more]
Unread 28-01-2014, 22:41
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud of
Legal Pneumatic Fittings - Nipples & Elbows?
R77 of the 2014 game manual states "Pressure transducers, pressure gauges, flow control valves, and connecting fittings" are legal. Can I assume that means any connecting fittings (which are rated for the pressure)?
We're looking to use 1/4" nipples and elbows to connect a tank to a nearby (stationary) cylinder, rather than 0.16" ID tubing for better flow rate. It looks legal to me, (especially as many teams use manifolds and cylinders with 1/4" npt ports).
Unread 28-01-2014, 22:54
jmartin jmartin is offline
AKA: Joseph Martin
FRC #0172 (Northernforce)
jmartin is on a distinguished road
Re: Legal Pneumatic Fittings - Nipples & Elbows?
Also according to R77 (e), any tubing used has to have an ID of 0.16". So I don't think using 1/4" NPT would be any more useful since you're still limited by the tubing.
Are you sure it isn't ports with 1/4" OD that you're thinking of? Because the 1/8" NPT ports we have fit 1/4" OD tubing. The 1/8" NPT ports have an ID of 1/8". It can be a bit confusing that the 1/8" NPT ports have labels on them saying 1/4.
Unread 29-01-2014, 00:01
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
We've done it in the past with no issue. You can always set it up with the fittings you want and fix it if it is not legal provided it is something you design to be easily changeable
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 29-01-2014, 01:50
AKA: Brendan Simons
FRC #5406 (Celt-X)
That's just it. Elbows and nipples are *not* tubing, so I am thinking that rule doesn't apply. We are planning to use 1/4" (nominal ID) pipe nipple to go into a 1/4" NPT port.
Unread 29-01-2014, 07:22
AKA: Joseph Martin
I see. I would be careful though, perhaps someone should ask about this on the q&a.
Unread 29-01-2014, 08:48
Guys,
Can we agree that "we used it in the past" is not a response.
Thanks.
Unread 29-01-2014, 09:09
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
There are very few restrictions on the use of "fittings", just be careful in defining a fitting. For example;
A quick exhaust valve is not a fitting, Nor is a check valve, but a 1/4" NPT close nipple is.
Also keep in mind that the 1/8" NPT restriction is for valves, not fittings. It is allowable to use fittings larger than 1/8" NPT, just not valves that have ports larger than 1/8" NPT.
Former Mentor Team 1771
Former mentor Team 4509
Unread 29-01-2014, 11:15
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The question is do you consider a nipple a fitting or a tube. I would tend to consider a close (short) nipple a fitting (legal). At some point it would transition into a pipe, which it really is, which be closer to tubing (not legal)
Keep in mind I am not the one inspecting your robot.
Unread 29-01-2014, 11:36
AKA: Brendan Simons
FRC #5406 (Celt-X)
Thanks for the input. I'm glad to get some backing on my interpretation.
Personally I'm not worried about a "pipe" being mistaken for "tubing". In this area, "tubing" usually means flexible (or at least, bendable). I'm guessing the rule is there to minimize damage if the vulnerable plastic tubing is cut or disengaged, which isn't a risk with hard pipe. I agree the question is probably worth a Q&A (I don't know how to do that though - I'm a first year mentor).
Unread 29-01-2014, 12:01
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
In that case "pipe" is not a fitting & not on the list of approved items. You probably OK with short nipples, without a Q&A only your inspector knows for sure.
Unread 29-01-2014, 12:33
The rule was simplified this year as 0.160 ID tubing has the same flow restrictions as saying Cv of 0.32 or about the same flow as 1/8" NPT port diameter.
Unread 05-02-2014, 07:18
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
If 1/8" NPT port diameter has a Cv of 0.32, then why would a solenoid with 1/8" NPT output advertise a Cv of 0.75? (mcmaster 6124K511)
Unread 05-02-2014, 07:37
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
The CV of a valve is a calculated number that includes the fitting size and the internal restriction of the valve and is basically just used for valves.
I think what Al was saying that using port size and hose ID is just a way of restricting flow like quoting a CV value.
Using CV can be pretty confusing because some valves give flow rate and some give CV which is not the same number. Eliminating the CV restriction and just using port size and hose ID is much easier to understand and inspect.
Unread 05-02-2014, 08:10
lcoreyl's Avatar
AKA: Milner
(emphasis mine)
right, so if a solenoid has a 1/8 NPT port, and the Cv of the 1/8 NPT is 0.32, then how can the Cv of the solenoid which includes said port and internal restriction be 0.75?
Unread 05-02-2014, 08:29
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Cv is the conductance of flow. (inverse of resistance.) It is a handy way of knowing how much a particular valve or fitting flows. The easiest example is with liquid. A valve with a Cv of 1 will flow 1 Gal/Min with a pressure drop of 1 PSI. Note the unit dependance. Cv with pneumatics is more difficult because the flow is referenced to standard conditions. (Cubic feet per min at 14.47 PSI at 32 F, or 60F or 68F or 70F). Lets not get started with metric definitions. Anyway Cvs determined with consistent standards with let you know the relative size without worrying about all the illogic & math behind it. Which is what standards are all about.
Any way no matter how free flowing a valve is, the restrictions in the 1/4 OD tube restrict the flow to something acceptable to the GDC. I think that was what Al was saying. You would have to know the length of tube to calculate the exact Cv for it.
