Go to Post When a team is a team, anything is possible - Bharat Nain [more]
Unread 29-01-2014, 10:27
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
Double Solenoid VOLTAGE?
Does it matter what voltage the double solenoid (electric valve) receives?
Unread 29-01-2014, 10:28
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Double Solenoid VOLTAGE?
Yes, if it is a 12V double solenoid, give it 12V. If it is a 24 V solenoid give it 24 Volts.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2014, 10:33
AKA: Akash
FRC #4684
We have a bunch of 12V batteries, but only 24V Solenoids. Is there an way we can make this work.
Unread 29-01-2014, 10:38
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Use the solenoid breakout which plugs into the 24V section of the power distribution board.
http://www.andymark.com/product-p/am-0868.htm
Kevin Li
596 - Sciclones
Unread 29-01-2014, 11:13
Rstrzelecki Rstrzelecki is offline
FRC #0135 (The Black Knights)
Rstrzelecki is an unknown quantity at this point
To test 24v solenoids our team spliced together 2 battery plugs with a fuse in between. It works but isn't the safest thing.
Unread 29-01-2014, 11:27
markgryzwa markgryzwa is offline
FRC #3206 (Royal-T-Wrecks)
markgryzwa is on a distinguished road
You should be using the +24V supply on the Power Distribution Board. It is the same supply that the CRIO uses.
Unread 06-02-2014, 23:21
goofy173's Avatar
goofy173 goofy173 is offline
Electronics Mentor
FRC #2867 (ElkLogics)
goofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to all
Probably too late now but use http://www.andymark.com/product-p/am-0875.htm so you don't have to choose.
