Go to Post The longer you play robots, the more you realize that it's not about the robots. - dtengineering [more]
Unread 27-01-2014, 12:38
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
ROBOREALM
Okay - I have roborealm downloaded but I do not understand how to make it work for this years competition. I am using the Axis IP camera and am programming in Java commandbase.
How do I make the image show up in the driver station?
Do I still have to write code for it and how do I do that?
How does it work?
I need a lot of help with this because I do not understand anything about it.
I looked at the tutorials and they did not help me at all.
ANY help will be GREATLY appreciated. THANKS!
Unread 27-01-2014, 13:04
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Re: ROBOREALM
How does it work?
I would advise not jumping into roborealm as the first step.
Follow the steps here to set up the camera:
http://wpilib.screenstepslive.com/s/...onent-overview
Once the camera is set up you should see the stream. No code required.
There is a button on the driver station that you may have to press to activate the stream.
Let me know once you have that up and running, and I can help you with referencing the camera via java.
Unread 29-01-2014, 01:05
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Re: ROBOREALM
We are interested in this topic as well, and have the camera set up. Would you please continue on to the part with java and roborealm?
Unread 29-01-2014, 10:36
mwtidd's Avatar
AKA: mike
Re: ROBOREALM
I have put together some videos and an extension to wpilib called HotCamera. If you email me (mwitdd@gmail.com). I can invite you to my dropbox where this is hosted.
I've also figured out how to "include" another project with your robot code, which will allows me to provide bug fixes and updates as I work on the code more.
Right now the library is only designed to answer the hot or not question. Due to performance issues with image processing on the crio, I am trying to keep the code as simple as possible. As I proceed through the season I may expand it as other features are requested.
As far a roborealm goes, I am trying to avoid it for now. I would prefer leaving the network open for robot coms and not take up any of the bandwidth for image processing.
Unread 29-01-2014, 11:03
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: ROBOREALM
A good place to start for learning RoboRealm would be the 2013 FRC RoboRealm page: http://www.roborealm.com/FRC2013/. They have tutorials on how to set up and use RoboRealm, as well as how to send data to the robot with NetworkTables.
Edit: they also have a page for this year: http://www.roborealm.com/FRC2014/
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Last edited by Domenic Rodriguez : 29-01-2014 at 16:54. Reason: Added an additional link
Unread 29-01-2014, 12:46
AKA: Brad
#0190 ( Gompei and the Herd)
Re: ROBOREALM
Here's some more documentation that might help for using RoboRealm with Java:
http://wpilib.screenstepslive.com/s/...with-roborealm
Hope this helps
Brad Miller
Robotics Resource Center
Unread 29-01-2014, 18:57
LFRobotics's Avatar
FRC #4623
Re: ROBOREALM
Okay - Thanks!
