Go to Post We are customers to FIRST. In that comes expectations. I don't want to hear another, "You should be grateful for everything FIRST does" nonsense when FIRST royally screws up. - MikeDubreuil [more]
Unread 25-01-2014, 12:21
ArzaanK ArzaanK is offline
FRC #1325 (Inverse Paradox)
ArzaanK is an unknown quantity at this point
Cannot setup M1013 Camera
Hello everyone.
Earlier this week, we received our brand new M1013 camera. However, we cannot set it up. I followed the WPI setup guide for the camera, but I cannot get the green light in the "Setup Axis Camera tool" to illuminate.
My IP address is set to 192.168.0.5 and the subnet mask is 255.255.255.0
I have plugged in the power supply, and I have tried both an ethernet and a crossover cable, all to no avail.
Any help would be greatly appreciated.
Arzaan Khairulla
Programmer/Driver
2013 Greater Toronto Regional East Winners with 1114 and 2056
2013 Galileo Division
Unread 29-01-2014, 13:46
Re: Cannot setup M1013 Camera
What happens if you point a browser to the camera URL?
I'm not sure why you'd need to, but you may try a hard reset of the camera and then try the tool. I believe this is accomplished by holding reset for ten or fifteen seconds while powering up.
Greg McKaskle
Unread 05-02-2014, 21:00
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
I have just taken the M1013 camera out of the box. I powered it up and the front status led ring (orange/green) does not light up. Could it be a bad camera?
Unread 05-02-2014, 23:07
Does the power indicator on the back light up green? If not, perhaps your power supply is faulty. Measure the voltage on its connector and verify that there is +5 on the center contact relative to 0 on the barrel.
