Go to Post Maybe it'll be a bumperless year!!! Nah...FIRST likes those things too much... - Fireworks 234 [more]
Unread 29-01-2014, 11:49
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Re: Half Sidecar PWM Ports Working
Try making some code that allows you to directly control each output (As a Jaguar... like jag[1].Set(joystick.GetAxis(1)) ). See if the problem is really hardware or just your code not doing what you think it does.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 29-01-2014, 14:14
afclsn afclsn is offline
Adam Claussen
AKA: Adam Claussen
FRC #4474 (Silver Circuit)
afclsn is an unknown quantity at this point
Yeah, we did this before we tried it with code for the mecanums, and it had the problems with the simple code.
Unread 29-01-2014, 14:15
Adam Claussen
AKA: Adam Claussen
Originally Posted by kevin.li.rit View Post
afclsn, Can you take a picture of your side car and electronics layout for us?
Thanks.
I will get one up shortly.
Unread 29-01-2014, 14:16
Adam Claussen
AKA: Adam Claussen
Originally Posted by afclsn View Post
We will definitely check this tomorrow, as this is a new assembly of the electronics and it very well could be the issue, I just didn't think to check it.
Just checked, all three power lights are green.
Unread 29-01-2014, 18:12
Adam Claussen
AKA: Adam Claussen
Here is our layout, without the motors connected.
We connect the black motor wire to the M- port, and the red motor wire to the M+ port.
Unread 29-01-2014, 18:22
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
I think you forgot the attachment. Correction it doesn't look like those pictures are public.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2014, 21:36
Adam Claussen
AKA: Adam Claussen
I noticed this when I posted it, but due to the securities on our school network, I couldn't easily fix them. Here they are now.
I case the photos don't work
http://imgur.com/5nqNRqG
http://imgur.com/1Ta5JIg
Unread 29-01-2014, 21:43
arizonafoxx's Avatar
arizonafoxx arizonafoxx is offline
FRC #4395 (T-Rex)
arizonafoxx is an unknown quantity at this point
I noticed you are using the ribbon cable. Could you have a backwards ribbon cable? I know those were floating around and its also easy to make backwards if you not careful. I am not sure of the symptoms of a backwards we have never had one backwards, but I know other teams have. Does anyone know if this could be the symptom they are seeing?
Unread 29-01-2014, 21:59
Adam Claussen
AKA: Adam Claussen
This was the pre fabricated ribom cable from the kit, plus we tried it with another pre fabricated cable (an actual cable, not a ribon cable), so I don't think this is the problem, but all these cables were new this year so it is a possibility. I will check it tomorrow with the ribon cable we used last year and know works.
Thanks.
Unread 03-02-2014, 13:10
Adam Claussen
AKA: Adam Claussen
So thanks for all the suggestion. Last Friday the sidecar started working again, and it was set up exactly as it was Wednesday and Thursday. This is good because the sidecar now works, but is also bad, because we don't know what went wrong. If you any other ideas as to what went wrong pleas let us know so that in the case it happens again we and other teams have a reference to go off of.
Thank you,
Team 4474
Unread 03-02-2014, 14:19
Bet the multipin connector was not fully seated at one or both ends.
Unread 03-02-2014, 14:46
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I was going to mention that driving your mecanums for a half hour might be just about the limit for a battery to handle. I know it is tempting to keep the testing going, but you really have to watch the power level during testing and driver training runs.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 03-02-2014, 14:52
Jared's Avatar
Jared Jared is offline
Use some 4-40's to hold the ribbon cable into the sidecar and digital module. We've had this happen in the past to us.
