Mecanum Alignment Problems
So we have made an awesome chassis this year with in frame gearbox's. We took 4 hex Nano-toughboxs from Andymark and disassembled them so that they could be put back together inside our 1.5 x 3 inch aluminum tubing (see picture). The Gearboxes work great, but that's beside the point, not all of our mecanum wheels aren't applying pressure to the floor equally. Furthermore the internal gearbox design doesn't allow for adjustments with moving the shaft up and down to level the robot. In the picture its the front right and back left that aren't touching as much as the other two (although they are touching). This makes us not move much on that parrallel but move fine on other vectors. Anyone have any suggestions how to level the robot? we are at a complete loss.
-Members of Team 3324 |
Re: Mecanum Alignment Problems
Your frame is probably too rigid. Good mecanum drives generally have frames that can conform to the carpet, or the mecanum modules have suspensions using springs. You are also not testing it fully weighed down. Add weight and see how things look.
We added more than the 120 lbs to it today and it didn't do anything. Unfortunately there isn't much adjusting you can do when you want an internal gearbox's...
Well, you also welded AND used gussets. Any way you can break your welds and see how it is with just the gussets?
We will have to try that tomorrow. We were hoping to avoid that but might have to do it. Unfortunately part of our goal was to build the base chassis like a tank. Which doesn't allow for much adjustment. Thanks for your input.
Our current idea to avoid taking everything apart and breaking the welds is to lag bolt the chassis into the concrete loading dock behind our work space and use a lever to fine tune the chassis by bending it.
#7
Regardless of what you do, good luck. |
#8
Your totally right, All 4 of our wheels are touching the floor but two are not touching the same amount so we have trouble on certain vectors. Would cutting the welds only 1/4 of the way down the height of the chassis allow enough flexibility to make this tiny adjustment (given we take the corner gusset plates off)?
#10
i have a pop sci from the 60's that shows old racing cart that allowed for one wheel to be 6" off the ground and the rest to be in-contact with he ground.
The designer did it all with out any moving parts just CrMo tubing and good welds. |
#12
I don't know if you'll like my suggestions... but here goes:
I REALLY don't think you'll want to lag-bolt it down and try to bend things into alignment. I think you will run a significant risk of distorting the tubes that house your gearboxes, and thus screwing them up with misaligned shafts, bearings, and gears. A few possible paths forward: Option A 1) Cut the front and rear cross-members in half 2) Use sleeves, blocks, or plates to reconnect the two halves of your chassis 3) Leave enough slop (or better yet, use slots) in whatever connecting part(s) you use to adjust the chassis for flat ground It will still be fairly strong, but won't conform to variations in playing fields. Option B 1) Cut the front and rear cross-members in half 2) Connect them together with sliding plates, rod ends, spherical bearings, some combination of these, or something I didn't list that allows relative movement in multiple axes between both halves 3) Mount a flexible 'deck' to the whole structure (1/8in polycarb?) to act as a suspension spring Perhaps the linkages get complicated and run the risk of binding, but it would somewhat conform to playing field surfaces. Option C 1) Completely remove the front and rear cross-members 2) Connect the two 'drive pods' with two sheets of a flexible material (again, polycarb comes to mind) on the upper and lower surfaces, acting as springs and allowing the whole chassis to conform to the floor. My favorite solution of the three, allows a lot of wheel movement (relatively speaking) and could be selectively stiffened to optimize performance. It also provides a lot of surface area for electronics/cRIO, etc. Best of luck! |
#13
Thanks for the ideas Guys. The plastic idea is brilliant! we will definitely try it.
#15
Ok so we tried the plastic and it helped slightly but did not completely resolve the problem. We are currently working on a jig to C-clamp the chassis to. We hope that we can then level it by slowly tightening it to a level surface with the C-clamps
