Go to Post Success is the indescribable feeling you get when you see something you worked so hard on in front of thousands of people. - SlamminSammy [more]
Unread 29-01-2014, 15:38
anthonygraff24 anthonygraff24 is offline
FRC #2872 (CyberCats)
anthonygraff24 is an unknown quantity at this point
Pneumatics Problems
I'm not sure if this is the right place to post this, but it encompasses multiple things so I'll post it here. My team has been trying to do pneumatics. We have the compressor properly wired to a spike which is properly wired to the PDB. The PWM cable from the Spike is wired to Digital IO #8. We are unsure where the pressure switch should be wired to. When we plug the PWM cable from the Digital IO into the Spike the Compressor runs without stopping. The Compressor constructor (in Java) currently reads:
Compressor comp = new Compressor (2,8);
Can someone please give us simple descriptions or pictures of where everything needs to be plugged in, and what the corresponding Constructor should look like. We have been struggling with this for a long time and just want to move on -.- .
Unread 29-01-2014, 15:39
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Pneumatics Problems
The spike should be wired to the relay portion of the DSC.
The pressure switch should be wired to a DIO on Input mode, one end on the input (sig) and one end on ground (-).
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2014, 15:41
Imaginary Friend
AKA: Kevin Li
Team Role: Student
The DIO I believe supplies 5 volts.
Kevin Li
596 - Sciclones
Unread 29-01-2014, 16:11
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The constructor should be: Compressor comp = new Compressor (Pressure switch I/O slot, Compressor Relay slot);
Relay and Digital I/O are different areas of the DSC. See attached.
