Re: SPIKE
R80 doesn't say the Relay can be off of the robot, it just says the compressor can. (Relays don't weigh that much, so don't know what you expect to gain.)
I am not the GDC. Ask on Q&A if you want an official answer. |
Re: SPIKE
We just have very little space.. and adding a spike will make our board more cluttered.
Re: SPIKE
The only official answer is the Q&A, but I would point you to R85 and R86:
Re: SPIKE
Regardless, I don't believe it is legal within the confines of FRC to have an off-board relay to go along with your compressor. |
Re: SPIKE
Is there any official rule about having a spike off robot for the compressor?
Re: SPIKE
If you want to be certain, please ask Q&A for the official answer. Your inspectors will thank you for doing so. "I read on Chief Delphi" is not a reason your robot should be legal. On the other hand, "Q&A says thus-and-so and our robot matches the Q&A, and here's the Q&A in print" has a pretty high likelihood of getting you past inspection with no problem if your robot actually does match. |
#7
We need help with our compressor. They coding is correct and the wiring is correct but the compressor won't turn on. Any suggestions?
Please and thank you. ![]() |
#8
Re: SPIKE COMPRESSOR Help!
Can you post a wiring diagram for your compressor and the code you're using? It is nearly impossible for us to troubleshoot without this info. Thanks!
#9
Re: SPIKE
Did you turn your robot on? jk check if you put the spike pwn cable in the right slot and if you have a multi-meter check if your spike is getting power, and if power is going to the compresor.
