Go to Post I believe that FIRST in itself is a reward. - link871 [more]
Unread 29-01-2014, 16:57
Grog_Maelstrom Grog_Maelstrom is offline
Team Welder
AKA: Will Galloway
FRC #0751 (Barn2Robotics)
Grog_Maelstrom will become famous soon enoughGrog_Maelstrom will become famous soon enough
Struggling with stored energy
If I have a cylinder(we never have used pneumatics on our team) and it pulls back 10 inches storing over 100 lbs of force, how fast can we release the arm to not slow down the 100lbs with resistance.
IE if it pulls back surgical tubing 10 inches and then extends, how fast can I get it going?
Im concerned that I have been unable to locate rules on speed of air released through solenoids.
-Grogo
Hey, I am Will G of team 751. I have nothing better to put here, so HI!
Unread 29-01-2014, 17:47
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Struggling with stored energy
The energy storage has to be in compliance with the rules. Since the situation you describe deals with air and deformation of robot parts, you're in compliance with the rules.
The rate that the cylinder can move is dependent on the resistance to flow into the cylinder. The biggest resistance to the flow is the solenoid valve. The rating for the solenoid valve's resistance to flow is the flow coefficient (Cv). Cv is generally defined as the flow rate of water through the valve in gallons per minute when the pressure across the valve is 1 PSI. Yes, it's defined with water, but the principle applies to air as well. If you use a solenoid valve with a Cv that is large, the air flows faster and the cylinder hence moves faster.
In past years there has been a limitation on Cv. This year's rules do not have a Cv limit. See R77 for the rules regarding solenoid valves. Then, pick a valve that is within the rules and allows your cylinder to move fast enough for your application.
Keep in mind that inspectors will look closely at robot safety. If they feel your mechanism is not sufficiently safe, they won't let you compete with it.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 29-01-2014, 17:50
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Could you describe your mechanism more? Are you using cylinders and pistons in tandem in your system?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 29-01-2014, 18:03
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Please do add some more details as my first understanding of how your system is set up could result in the air cylinders disassembling themselves...IE, the piston in the cylinder could hammer against the end very hard if the surgical tubing is helping accelerate it as well as the air pressure.
Unread 30-01-2014, 13:47
Team Welder
AKA: Will Galloway
Thanks for the help. The idea is that a cylinder pulls pack on a compression spring that then we release, impelling the ball with force under the equation
(force released in the spring) - (resistance from cylinder)
where (resistance in cylinder) is limited by the pressure
