Re: Acceleration Ramp Up Code
Can you elaborate on what you want to do to cut down on acceleration? The way I am familiar with manipulating the drive is from the joystick outputs. I don't think you can manipulate the motor output itself since the motor outputs are used the vi given by wpi. I wouldn't want to mess around with their vis until it becomes necessary.
I did! Thank you for posting that. The linked paper is full of good ideas.
Actually yes I read through yesterday, and was interested in the "Slew Rate" and "Low Pass Filtering" sections, as we were thinking of doing it in a similar fashion but didn't know how to implement it. So that helped a lot in that regard, but I'm still wondering. Are there better ways to do this? Which of these options do you think is best?
In a text-based language, it would look something like this: Code:
change = joystick - limitedJoystick; if (change>limit) change = limit; else (if change<-limit) change = -limit; limitedJoystick += change; limitedJoystick is the rate-limited joystick value you use to control your motors. |
#7
Thanks for the help!
#8
I've attached an example that helps visualize what happens when you use the low pass filter option. It has two different low pass filter implementations. One of them is simply averaging your joystick outputs over a number of samples. This method makes the most sense intuitively if you have not studied low pass filters before.
As far as implementing this, I see a couple of options. The easiest might be what was said before, which is to put a block between your joystick and your motor drive functions. The other option is to put whatever function you want to use into a VI and assign that VI to each motor as its 'transfer function'. This way you use all of your motor drive functions as you normally would, both in teleop and auton, and your ramp function will always be working. For both of these options, if you create your ramp function as a SubVI and you create multiple instances of it, it will be important to set your execution to Reentrant for that SubVI. This is File -> VI Properties -> Execution -> Reentrant execution with option Preallocate clone for each instance Edit: Added the PID Output Rate Limiter as well which is what Ether describes. Last edited by wt200999 : 30-01-2014 at 17:17. Reason: Better Example |
