Does the perimeter of the robot include the drive wheels?
Our robot has a 1/2 in. excess on the back and our team is wondering whether or not the wheels count as the frame or they count towards the 20 in. extension? We reviewed the rules many times but there seemed to be no direct answer to this fact. Any team answer or personal answer to the question is welcome. |
Re: Perimeter Details
In short, no, I don't think they do. Which means then your wheels start outside the frame perimeter, let alone making a legal bumper to accommodate this. Let me look over the rules... EDIT: Quote:
Go to Q&A for the official answer, but...
The frame perimeter needs to be established by non-articulated (non-moving) parts of your robot. Also, the frame perimeter limit is 112" with no tolerance. 112 inches is 112 inches is 112 inches. Your robot must start entirely within that perimeter (with the exception of MINOR protrusions like bolt heads). So, unless your wheels somehow start within the 112" perimeter and then slide outward after match start, you're not in compliance with the starting configuration rule. Also, a wheel is generally accepted to be neither a minor protrusion or non-articulated. |
It sounds like you're going to have to extend your frame to encompass your wheels. I hope that won't make you exceed the perimeter limit.
Or, if their wheel size is inconsequential to their design, switch to smaller diameter wheels.
#7
See the Blue Box in R4.
If a ROBOT is designed as intended and pushed up against a vertical wall (in STARTING CONFIGURATION and with BUMPERS removed), only the FRAME PERIMETER (or minor protrusions) will be in contact with the wall. |
#8
Q&A posted an answer on this very topic.
I suggest someone ask Q&A how the "non-articulated" part of the definition would affect that ruling, as soon as possible. (Or: Q&A just failed a test on the rules they wrote.) |
