Go to Post If you are old then our lead mentor is ancient. Oh wait, he is. Oh wait, that makes me ancienter. - JaneYoung [more]
Unread 28-01-2014, 18:26
sergioCorral842's Avatar
sergioCorral842 sergioCorral842 is offline
College Student
FRC #0842 (Falcon Robotics)
sergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to behold
Robot Losing Connection
We recently started having an issue where we would lose all communication with the robot over wifi. Downloading code over wifi works but when we start driving around or just have it enabled, the communication and robot code light will randomly shut off then come back on at random times for less than a second then shut off again.
The only way we can reconnect to it is to shut off the robot and restart. However, this is becoming an issue because it is starting to happen frequently. I have reconfigured the bridge and it fixed the issue for about an hour then it starts happening again.
Team 842 Falcon Robotics: 2011-2015 (President, Head Programmer, Drive Team)
Arizona Regional Winners: 2012-2014 (Thanks 610, 1212, 1726, 3944, 2486, 2403)
Curie Division Semi-Finalists: 2014 (Thanks 1311, 2013, 2928)
Las Vegas Semi-Finalists: 2015 (Thanks 3495, 4415)
Curie Division Quarter-Finalists: 2015 (Thanks 107, 228, 649)
2015 - 2016: Programming, Drive Team, and Strategy Mentor for Team 3187, The Titans
Studying Computer Science- Software Engineering at ASU (Class of 2019)
Unread 28-01-2014, 18:44
Re: Robot Losing Connection
The charts tab may give more info on what is happening. Pay attention to the CPU usage, the lag and the packet loss.
By the way, for historical runs, go to the charts tab and launch the viewer. It is also in the Start menu.
Perhaps you want to post an image of the chart that shows the issues.
Greg McKaskle
Unread 28-01-2014, 20:00
Are you in an area with a lot of wifi access points?
Unread 29-01-2014, 13:28
College Student
No, I am not. I am having a different issue now. The robot code light continuously blinks on and off. The communication light stays green.
Unread 29-01-2014, 13:49
That probably means either that your robot code is running too slowly somewhere and blocking execution, or conversely too fast and sucking up all the CPU.
As a first diagnostic look at your event log and pay particular attention to the CPU utilization line.
As a second diagnostic look at the Driver Station Diagnostics window for repeating error messages.
Unread 29-01-2014, 18:01
College Student
So I believe I might have figured out the issue. Since we are using 6 cims on our robot, when we go full speed, the amperage caused by the cims could be causing the radio to go bad. I am going to write some code that prevents the motors from instantly going to full power. Instead, it will accelerate to it. Will post back if it works.
Unread 29-01-2014, 18:32
If you have the radio wired properly, it should not be caused by current draw. However, if you have your radio placed near your CIM motors, you could see an issue.
Unread 29-01-2014, 18:45
College Student
I just tested driving on blocks with the radio on the outside of the robot (Completely away from the Cims). After about 25 seconds of driving the robot code light started flashing on and off and then I could not connect anymore.
Unread 30-01-2014, 12:12
The easiest thing to check right now is the power wiring to your D-Link. Make sure it's done as follows:
dedicated 12v output on Power Distribution Board (white Wago plug)
to
red and black wires on 12v-to-5v converter module
yellow and black wires on 12v-to-5v converter module
to
D-Link 5v power input
Any other wiring scheme will potentially cause the D-Link to lose power when the battery voltage sags.
