Go to Post Your opions and statements DO reflect on your team and its' reputation, regardless of what your disclaimer says. - Chris Fultz [more]
Unread 29-01-2014, 19:26
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Re: Mecanum Wheels
What kind of mecanem wheels? Chain or belt?
Unread 30-01-2014, 11:14
silverD's Avatar
silverD silverD is offline
Build Mentor
AKA: Nate
FRC #2052 (KnightKrawler)
silverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to behold
Re: Mecanum Wheels
Tyler,
Please read the usage section on the AndyMark page you linked. Are you using chain to drive the wheels? If so, spacers and a sprocket. Live axle from a gearbox? Then you will need the corresponding hub for your axle. AndyMark, Vex Pro, and others should carry the parts you need. Do you have more detailed info about your drivetrain that you could provide so we can better help?
