Go to Post Pro safety tip: put a string through coil springs that is tied off securely on the robot frame. This will help prevent the spring from jumping out and killing an inspector if it snaps. - Ninja_Bait [more]
Unread 29-01-2014, 19:30
bs7280 bs7280 is offline
FRC #3734
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
LED rings
We would like to buy a led ring for our Axis Camera. The only ones that we can find are all White. has anybody had any success with using a white LED ring? Most of the teams I have seen have used a green ring. Also, white size diameter do we need to use with the axis camera?
Unread 29-01-2014, 19:40
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Re: LED rings
Where did you find the rings? We would like to use one but cannot locate a supplier.
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 29-01-2014, 19:42
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: LED rings
Try Super Bright Leds. They are called ascent rings
Unread 29-01-2014, 19:44
kghaemi96 kghaemi96 is offline
Driver/Know-it-all/Engineer
AKA: Kevin G
FRC #2637 (Panthers)
kghaemi96 is an unknown quantity at this point
Re: LED rings
Our team has used green LED's in the past. I believe the reasoning is that green lights have a slightly higher intensity therefore any reflections are easier for the Axis camera to find. We are trying to use a green LED ring because of the issues we have had with white ones. Our previous white ones have had an issue being recognized by the Axis camera after being reflected. A lot has to do with the amount of outside light that may interfere with the camera's readings. Personally I would suggest getting a green LED ring just because of the issues I have seen with white ones.
As for the diameter, personally I suggest getting the 60mm because it fits around the axis camera perfectly. We are still trying to find a good way to mount it. Our team may end up just using double sided tape if we cant figure anything better out.
Hope that helps
Kevin
Why not both? ¿Por qué no los dos?
2011 Las Vegas Regional Semifinalists (5th Alliance Captain)
2012 Las Vegas Regional Semifinalists (2nd Alliance)
2013 Inland Empire Regional Quarterfinalists (7th Alliance)
2014 Central Valley Regional Quarterfinalists/Creativity Award (7th Alliance Captain with 2085 and 5136)
2014 Los Angeles Regional Semifinalists (4th Alliance Captain with 696 and 5102)
Unread 29-01-2014, 20:16
FRC #3734
Re: LED rings
is there any alternative to the axis camera?
Unread 29-01-2014, 21:07
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Re: LED rings
It doesn't matter what camera you use, if you want to be able to track the vision targets, you're going to need to shine a light of some sort at it.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 29-01-2014, 21:10
rsegrest's Avatar
Re: LED rings
Thank you!!
~ Unknown
Unread 29-01-2014, 21:17
FRC #3734
Re: LED rings
I only ask because we need to buy a camera, and we really do not want to spend $200 on an axis camera if not necessary. We do have a kinect, if that will work.
Unread 29-01-2014, 21:28
INTENSITY
Re: LED rings
You can use the Kinect, as well as most webcams, however, since these require a USB connection, you'll need a separate onboard processor to do your vision processing. This often requires a basic understanding of Linux, and if you have not played around with this form of vision processing, I would say it's a little too late in build season to be poking around with it.
