Go to Post Off season is a good way to go outside the district. - 346CADmen [more]
Unread 18-01-2014, 14:18
Trevster526 Trevster526 is offline
FRC #3570
Trevster526 is an unknown quantity at this point
x-Box Buttons in Labview
I need help programming buttons for my x-box controller in labview.
Unread 18-01-2014, 14:26
Z1599 Z1599 is offline
FRC #1599
Z1599 is an unknown quantity at this point
Re: x-Box Buttons in Labview
The Xbox controller functions the same way as a normal logitech controller does with a handful of exceptions.
A) it has 6 axes
B)it has 10 buttons
C) the D-pad doesn't cooperate at all.
Axis 1:Left X Axis
Axis 2:Left Y Axis
Axis 3:Triggers (L- R+)
Axis 4:Right X Axis
Axis 5: Right Y Axis
Axis 6: D-pad
1: A Button
2: B Button
3: X Button
4: Y Button
5: Left Bumper
6: Right Bumper
7: Stop/Back Button
8: Start Button
9: Left Thumbstick Button
10: Right Thumbstick Button
I hope that helps. Good luck!
Unread 29-01-2014, 20:46
Herbblood's Avatar
Herbblood Herbblood is offline
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Herbblood is an unknown quantity at this point
I actually found that with the triggers on axis 3 that the right is negative and the left is positive,
but otherwise everything else is the same
Off to WPI!
Go OxBE4
Unread 03-02-2014, 01:39
gerry gerry is offline
FRC #4144
gerry is an unknown quantity at this point
Red face Re: x-Box Buttons in Labview
So this is what i ended up with after figuring out how to program the xbox controller do you guys think it'll work
