Go to Post We all know that with mechanical systems, once all the noise has leaked out, the system quits (therefore quiet running mechanical systems last much longer :^) - KenWittlief [more]
Unread 27-01-2014, 21:50
akavoor13 akavoor13 is offline
FRC #4856
akavoor13 is an unknown quantity at this point
Angry Driver Station doesn't communicate with D-Link
We imaged our cRIO and configured our radio. The PC sees the radio, but the Driver Station doesn't. Do I need to assign an IP address to the radio manually? I thought the configuration utility would take care of that. Please help!
Thanks,
4856
Unread 27-01-2014, 22:18
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Driver Station doesn't communicate with D-Link
Have you input your team number into the Driver Station app? There should be a box on the Setup tab with an XXYY in it. Change this to your team number and select the appropriate NIC to set up.
I'm right 90% of the time, so why worry about the other 3%?
Unread 27-01-2014, 22:24
So the "bridge" light isn't lighting up?
Technically, the Driver Station doesn't really have to talk directly to the robot radio, as long as it can talk to the cRIO.
Is your PC IP setup correctly?
Unread 28-01-2014, 00:05
What does "see" mean here?
Unread 29-01-2014, 21:05
FRC #4856
The "bridge" light on the DS panel doesn't turn on. The internet was originally disabled on the PC I am working with. After I enabled internet connectivity, I wasn't able to "communicate" (on the DS) with the cRIO.
Unread 29-01-2014, 22:01
To use the Internet you probably changed the PC's IP to DHCP.
That would stop the PC from communicating with the rest of the robot network (bridge,cRIO).
The PC IP needs to be 10.48.56.5 (wired) or 10.48.56.9 (wireless) to act as a Driver Station.
