Go to Post Robots can be fixed, glory is forever - Brandon Holley [more]
Unread 29-01-2014, 20:48
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
What're these part called?
https://docs.google.com/file/d/0B45y...4SWdaOUFz/edit
Can anyone describe the parts circled in red? Also it'd be great if we knew where to buy it. Our team is situated Calgary, Alberta, Canada. We searched AndyMarks for the T shaped valve but didn't find one with 3 female ports. As well apparently we don't need the top part circled in red if the bottom part circled in red comes in size 1/8 by 3/8 inch where the pressure relief valve doesn't need an enlarger.
Btw the size is 1/8" and the enlarger takes in 1/8" and gives out 3/8". This seems to be the only thing (besides cylinders) that we need to work our pneumatic system.
Unread 29-01-2014, 20:53
MrBasse MrBasse is online now
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: What're these part called?
Your google doc file is doesn't have permissions set for me to view it. Make the change and I'd be happy to help.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 29-01-2014, 20:59
FRC #4733
Sorry about that. All fixed!
Unread 29-01-2014, 21:09
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
The fittings you circled are standard brass pipe fittings, you should be able to pick them up at a local hardware store.
Unread 29-01-2014, 21:13
FRC #4733
But they are missing the thing that attaches them to the connector. http://www.andymark.com/product-p/am-2002.htm
That is just a standard brass "t" fitting with female ports. If you can't find them locally, you can find them online somewhere like automation direct.
Andrew Basse
Unread 29-01-2014, 21:15
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
The part in the bottom red circle is a brass female 1/8" T. The piece above it is a 1/8" male to 1/4" female adapter. The adapter is required to connect the relief valve (1/4") to everything else (1/8"). I can't find any of the female T's at AndyMark, but here is a link to the same product from AutomationDirect:
http://www.automationdirect.com/adc/...e_Tee/BFFT-18N
The adapter is available on AndyMark:
http://www.andymark.com/product-p/am-2381.htm
and also at AutomationDirect:
http://www.automationdirect.com/adc/.../BFMFR-14N-18N
My team used our $20 AutomationDirect voucher to buy a whole bunch of these brass fittings, and I think it was money well spent.
Unread 29-01-2014, 21:29
FRC #4733
Thanks! The right sized T seems impossible to find at hardware stores.
