Go to Post Instead of prototyping with plywood and machining metal for the final version, they make their prototypes out of sheet metal and machine the final robot out of wood. :) - Chris is me [more]
Unread 29-01-2014, 21:45
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: Help: Torque to Linear force conversion
We are using the motors to pull down our catapult which is connected to surgical tubing at the other end of a fulcrum. The calculated value for the tubing pull force is 516 lbs when the tubing is completely stretched (I realize that is a ton of force). The mechanical advantage that our winch has is 4 due to the length of our catapult arms (the winch will be connected to the end of the catapult arms).
It's a lot of info to explain let me know if I missed anything
