Go to Post I'm pretty sure there is a federal sequester on the bandwidth coming out of LSR. - PayneTrain [more]
Unread 29-01-2014, 18:27
Maximillian's Avatar
Maximillian Maximillian is offline
AKA: Max Westwater
FRC #5254 (HYPE)
Maximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant future
What to use as a electronics board.
I am a part of a rookie team and we are trying to decide on what to use to mount our electronics. We have very little machining resources but may be able to call in our one favor of the year to get a neighbor team to make this for us. We are using a VersaChassis with 3 CIM ball shifters on it. I have attached a drawing of what the board has to look like to not get in the way of the belts or the shifter 3rd stage.
We were thinking of using a couple different things. One way a sheet of aluminum then polycarbonate on top to prevent short circuits. We also thought of wood then polycarbonate, just polycarbonate or the polycarbonate with holes in it that andymark sells. We were then going to use industrial strength Velcro to attach most of the components.
Are there any suggestions of what worked for your team in the past or what was easiest.
Thanks
Unread 29-01-2014, 18:29
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: What to use as a electronics board.
I would just cut this out of a 1/8th inch sheet of polycarbonate with my 10 dollar Jigsaw. No AL or wood.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2014, 18:34
AKA: Max Westwater
FRC #5254 (HYPE)
Where would you get it from? If you get it on McMaster-Carr then which version would you get? The impact resistant or the ultra-impact resistant?
http://www.mcmaster.com/#polycarbonate-sheets/=qgtocq
Unread 29-01-2014, 19:09
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
We just purchased two rectangular pieces and used the flanges to mount the boards. Clamped them down and match drilled some mounting holes.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 29-01-2014, 19:18
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Traditionally we have used 1/4" birch plywood for an electronics board, doubt we will change up the final one this year but who knows.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 29-01-2014, 20:32
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
We use 3/16" ABS as it's more rigid than polycarbonate. We've also used 3/16" expanded foam PVC. That's not a indestructible but it's a tiny bit lighter.
Unread 29-01-2014, 21:10
Billfred's Avatar
Billfred Billfred is offline
I've used aluminum, I've used lexan, I've used wood. Unless you're in weight trouble or have other considerations, use what you can fabricate. You can get nice looking results from a decent piece of wood (birch or similar) and a coat of paint.
Unread 29-01-2014, 21:11
yash101 yash101 is offline
AKA: null
Start with wood. the cRIO grounds, so wood will help get that out of the equation. It is also very strong!
Unread 29-01-2014, 21:24
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
To echo above, run whatever you can get made the quickest, cheapest, and nicest. I'm guessing that any machining resources you could ask from other teams are better spent improving your manipulator than on your electronics board.
My team uses perfboard, which is really easy to cut and makes mounting really nice and easy. We're using 1/4" this year, but 1/8" is fine for most applications.
Just use a jigsaw or cut it by hand. Pretty belly pans are nice, but in this case, good doesn't always need to equal pretty.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 29-01-2014, 21:31
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Wood will get you the most strength to weight ratio. 3/8" or 1/4" plywood works pretty well for everything. You can attach components with wood screws since velcro tends to shift and get messy. What ever you decide on doing, wire extremely neatly. It will be worth the time you spend when you have to do trouble shooting or adding/removing/replacing components
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 29-01-2014, 22:02
AKA: Max Westwater
FRC #5254 (HYPE)
So what do you think about Velcro? Is it an okay thing to use for parts like motor controllers? Or would use just use screws and bolts for everything?
Unread 29-01-2014, 22:07
AKA: null
VELCRO IS AMAZING. We had very few problems with velcro last year(read: it fixed some problems). It allows you to easily move a component while you are trying to debug it!
Unread 29-01-2014, 22:09
Billfred's Avatar
It can be done, just make sure it adheres well. You'll probably have more issues with wood there, but using a staple gun may help you out on the board side. Don't be stingy with the stuff; the weight penalty is minimal, but the how'd-that-break-free? penalty is often not minimal.
Unread 29-01-2014, 22:20
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
We cover our ABS control board with 4" wide Velcro loops. That way we can move components around at will and change broken components easily. A good source is
http://www.uline.com/BL_6426/Hook-and-Loop-Tape
Unread 29-01-2014, 22:29
Maximillian,
Velcro would be fine like others have said, my reasoning for suggesting screws is that velcro does not rigidly connect the component to the board. If you have tight wiring runs, the controllers often like to rotate on the velcro. Wood screws are rigid and alleviates that problem. You may try out both and see how each works and which you like better. I cannot stress enough how what ever you do, keep it neat and tidy. A rats nest looks unprofessional and leads to issues
