Go to Post Leave FIRST? That's an option? =) - treffk [more]
Unread 14-02-2003, 10:03
Mark Jones Mark Jones is offline
Engineer - Team 343 MIM
FRC #0343 (Metal-in-Motion)
Mark Jones will become famous soon enoughMark Jones will become famous soon enough
Send a message via AIM to Mark Jones
Drill Motor Speed Difference
Has anyone noticed the huge difference in the drill motor speeds between forward and reverse? We measured the current draw on all of our Bosch drill motors at no-load in both forward and reverse and noticed a big dip in current draw and speed in reverse. Too much to compensate with programing!! Last years drill motor indicated only a very slight difference in current and speed.
Therefore, if any of you are using the Bosch drill motors for your drive system and are experiencing some tracking problems this is the reason. You need to add an additional spur gear to change the direction of your final output on one side to ensure that both motors are turning the same direction.
Mark Jones
Metal-in-Motion (MIM)
Team 343
Unread 14-02-2003, 10:53
Dave Dave is offline
#0654 (Mechateuthis Dux)
Dave is an unknown quantity at this point
Send a message via AIM to Dave
Yessss... this is a problem with us too, we ARE compensating for it in programmin.. I think a value of around 175 on the faster motor will = a 255 or whatever on the slower one... play with it... and get a tachometer on it... I don't know much... I don't do the whole programming thing.
I like shiny moving things... perfect!
Unread 14-02-2003, 15:23
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Does anyone have an exact value for the differences? I'm doing the programming for my team, and we realized this would be an issue, but not that much of an issue. Last year we did something crazy with the EEPROM, but this year we'd like to do something on the fly, but we need the difference between the speeds so we can make it at least semi-work.
AIM --> Woloi
Email --> ian@woloschin.com
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Forward/Reverse difference in drill motors. archiver 2001 15 24-06-2002 02:38
Difference in forward/reverse drill motor speed archiver 2001 25 24-06-2002 00:21
