Go to Post So basically, the advantage of #35 is that it allows you to be sloppier in your design and fabrication. If you pay close attention to these details, you will never have a problem with #25 chain. - Jim Zondag [more]
Unread 29-01-2014, 00:29
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
How to access Axis camera feed with OpenCV
Our team had some trouble accessing our IP camera's stream in OpenCV, so here's what we did in case other teams are having similar issues.
We are using OpenCV-2.4.8 and JavaCV-0.7.
IPCameraFrameGrabber grabber = new IPCameraFrameGrabber("http://YOUR_CAMERA'S_IP_ADDRESS/axis-cgi/mjpg/video.cgi?resolution=480x360&fps=INSERT_FPS_HERE");
grabber.start();
For example, our team (2601) has the following URL:
http://10.26.1.11/axis-cgi/mjpg/video.cgi?resolution=480x360&fps=100
Hope this helps.
Unread 29-01-2014, 10:34
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: How to access Axis camera feed with OpenCV
My team has also been working with OpenCV (using the official 2.4.7 Java bindings), and we have been using this URL successfully:
http://10.xx.yy.11/mjpg/video.mjpg
I wonder if there are any differences between the two URLs other than that you can specify camera settings in your URL.
Also, I'm curious as to your decision to use JavaCV now that OpenCV includes Java bindings. Would you say there is an advantage to using JavaCV over the official bindings, or does JavaCV supplement them?
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 29-01-2014, 15:31
NWChen's Avatar
Alum
We tried http://10.xx.yy.11/mjpg/video.mjpg but kept getting errors. This setup uses the M1011 with the DLink Rev A though.
We supplemented OpenCV with the JavaCV wrappers, but JavaCV had most of the functions we needed. Team 341's DaisyCV example used JavaCV so this was just a bit more convenient. I don't know about any other advantages.
Unread 29-01-2014, 22:31
charr charr is offline
FRC #3504
charr is an unknown quantity at this point
I'm trying to coax my daughter's team in the direction of OpenCV and wondered if you could share any more pointers or code samples.
Thanks,
Chris
Unread 30-01-2014, 00:34
Thanks,
Chris
Let me prefix this post by stating that I've only been working with OpenCV for about a month, and am by no means an expert. This will be my team's first year using it. Nevertheless, here are some of the resources I've been using to learn OpenCV:
- The OpenCV documentation and tutorials are well written and a great reference. The first class you will want to learn about is the Mat class (short for Matrix), which is what images are stored as. Then look into the Core, Imgproc, and Highgui modules.
- If you use the Java bindings of OpenCV, then you will want to refer to the Javadocs
- This thread contains links to many valuable resources regarding OpenCV and vision processing.
- The ScreenSteps Live documentation has a section that explains the algorithm that the sample vision code uses. Although it uses NI Vision as opposed to OpenCV, many of the principles still apply.
- DaisyCV, Team 341's 2012 vision code, is an excellent example of an FRC vision system built with OpenCV. Note that it is a SmartDashboard extension and uses WPIJavaCV, which differs a bit from modern OpenCV.
We'll likely be posting our code after the end of the season on GitHub (shameless self plug ), but if you'd like to see a sample of the code I have now to help you get started, send me a PM and I'll see what I can do.
Unread 30-01-2014, 13:45
NWChen's Avatar
Alum
Same here, I'm no expert either but feel free to PM me. OpenCV samples are in our GitHub repo, mostly gathered across the Internet (the repo's not very well documented - sorry).
You may find it easier to begin with OpenCV-Python or SimpleCV, which have great documentation. Here's a StackOverflow post with a bunch of other good resources.
