Go to Post There's nothing wrong with the loader [dividing by zero], John just misses us 229'ers and wanted everyone to know :-P - Jay Trzaskos [more]
Unread 29-01-2014, 22:32
Billfred's Avatar
Billfred Billfred is offline
Re: What to use as a electronics board.
Originally Posted by Dale View Post
We cover our ABS control board with 4" wide Velcro loops. That way we can move components around at will and change broken components easily. A good source is
http://www.uline.com/BL_6426/Hook-and-Loop-Tape
If you're looking at having to back the velcro up with staples, also look at McMaster 94975K42 (hook) and 94975K82 (loop). 57" and 60" wide respectively, $17.20 and 10.39/foot. Then spring for the adhesive stuff on your components.
dtengineering's Avatar
AKA: Jason Brett
If you go with screws and nuts, look into nylon screws and nuts. I get them at Home Depot and they save 1-2 pounds relative to steel.
Jason
Unread 30-01-2014, 08:59
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Originally Posted by Maximillian View Post
Where would you get it from? If you get it on McMaster-Carr then which version would you get? The impact resistant or the ultra-impact resistant?
http://www.mcmaster.com/#polycarbonate-sheets/=qgtocq
Just the impact resistant. I don't imagine my board taking any direct shots and it is still plenty strong. I'm also not worried too much about the sag either.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 30-01-2014, 10:22
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Originally Posted by cadandcookies View Post
My team uses perfboard, which is really easy to cut and makes mounting really nice and easy. We're using 1/4" this year, but 1/8" is fine for most applications.
I'll second this. We've used perfboard or similar material for years. It is light and easy to mount electronics to, particularly if you use zip ties to mount parts, which we do.
Unread 30-01-2014, 17:01
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
We like 6mm foamed PVC plastic. It's much lighter than the solid plastics and plenty strong enough for an electrical board. Here is one manufacturer:
http://www.sintrapvc.com/
Unread 31-01-2014, 08:30
WildStang has used aluminum perf stock for many years. We have to add an insulated sheet under the cRio to keep the case from conducting to the frame. The perf allows you to use tywraps to hold everything in place, controllers, wires, etc.
