Go to Post The few people who don't ever make mistakes are the same people who simply don't do anything. What people do after they make a mistake tells others what they are made of. - Andy Baker [more]
Unread 30-01-2014, 11:17
nitneylion452's Avatar
AKA: Joe Lee
Re: SPIKE COMPRESSOR Help!
Originally Posted by SMArtbelle View Post
We need help with our compressor. They coding is correct and the wiring is correct but the compressor won't turn on. Any suggestions?
Please and thank you.
Can you post a wiring diagram for your compressor and the code you're using? It is nearly impossible for us to troubleshoot without this info. Thanks!
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 30-01-2014, 15:04
jlee0119 jlee0119 is offline
FRC #2849 (Ursa Major)
jlee0119 can only hope to improve
Re: SPIKE
Did you turn your robot on? jk check if you put the spike pwn cable in the right slot and if you have a multi-meter check if your spike is getting power, and if power is going to the compresor.
