Go to Post Achieving a goal by merely finishing, or reaching mediocrity is not acceptable; Excellence is the only satisfactory result. - AdamHeard [more]
Unread 29-01-2014, 16:16
ElectricNoodle's Avatar
ElectricNoodle ElectricNoodle is offline
AKA: Ted Pabst
FRC #2789 (TEXsplosion)
ElectricNoodle is an unknown quantity at this point
Question Acceleration Ramp Up Code
Our team is trying to cut out some of the bumps in acceleration by writing a "ramp up" code. For example, if we want the motor power to go from 0 to 100, we want there to be other steps in there to prevent jumping ss in the acceleration. Any ideas of how to do this?
#code on code on code
Unread 29-01-2014, 16:59
Kevin Phan's Avatar
Kevin Phan Kevin Phan is offline
College Student
FRC #0357 (Royal Assault)
Kevin Phan will become famous soon enoughKevin Phan will become famous soon enough
Re: Acceleration Ramp Up Code
Can you elaborate on what you want to do to cut down on acceleration? The way I am familiar with manipulating the drive is from the joystick outputs. I don't think you can manipulate the motor output itself since the motor outputs are used the vi given by wpi. I wouldn't want to mess around with their vis until it becomes necessary.
Unread 29-01-2014, 17:01
http://thinktank.wpi.edu/article/140
Unread 30-01-2014, 12:08
AKA: Ted Pabst
To be more specific, I'm essentially looking for the best way to do what you described and manipulate the JOYSTICK outputs to ramp up acceleration of the motor INPUTS. Sorry I didn't really explain it well the first time, but if you have any ideas they would be greatly apprieciated.
Unread 30-01-2014, 12:22
Did you read the link in Post #3 ? It explains how to do exactly what you indicated above.
Unread 30-01-2014, 12:29
gnunes gnunes is offline
FRC #1391 (Metal Moose)
gnunes has a spectacular aura aboutgnunes has a spectacular aura aboutgnunes has a spectacular aura about
I did! Thank you for posting that. The linked paper is full of good ideas.
AKA: Ted Pabst
Actually yes I read through yesterday, and was interested in the "Slew Rate" and "Low Pass Filtering" sections, as we were thinking of doing it in a similar fashion but didn't know how to implement it. So that helped a lot in that regard, but I'm still wondering. Are there better ways to do this? Which of these options do you think is best?
Unread 30-01-2014, 13:06
Actually yes I read through yesterday, and was interested in the "Slew Rate" and "Low Pass Filtering" sections ...Which of these options do you think is best?
From what you described in your original post, it sounds like you want the slew rate limiter.
In a text-based language, it would look something like this:
change = joystick - limitedJoystick;
if (change>limit) change = limit;
else (if change<-limit) change = -limit;
limitedJoystick += change;
limit is the amount of change you will allow every iteration (e.g. every 20 milliseconds for TeleOp)
limitedJoystick is the rate-limited joystick value you use to control your motors.
Unread 30-01-2014, 14:36
AKA: Ted Pabst
Thanks for the help!
Unread 30-01-2014, 15:03
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
I've attached an example that helps visualize what happens when you use the low pass filter option. It has two different low pass filter implementations. One of them is simply averaging your joystick outputs over a number of samples. This method makes the most sense intuitively if you have not studied low pass filters before.
As far as implementing this, I see a couple of options. The easiest might be what was said before, which is to put a block between your joystick and your motor drive functions.
The other option is to put whatever function you want to use into a VI and assign that VI to each motor as its 'transfer function'. This way you use all of your motor drive functions as you normally would, both in teleop and auton, and your ramp function will always be working.
For both of these options, if you create your ramp function as a SubVI and you create multiple instances of it, it will be important to set your execution to Reentrant for that SubVI. This is File -> VI Properties -> Execution -> Reentrant execution with option Preallocate clone for each instance
Edit: Added the PID Output Rate Limiter as well which is what Ether describes.
