Go to Post Silly FIRST mentor -- actually spending brain power caring about a sporting event occuring during build season! - Aidan F. Browne [more]
Unread 29-01-2014, 22:04
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Get Available Memory
I'm working on a new auton system and one of the main problems raised by my associates was how much memory the system was using. Is there a way to get the amount of memory currently available to the program?
Unread 29-01-2014, 22:43
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Get Available Memory
You can view many performance metrics using the log file viewer, but I don't think it displays available memory.
The only mechanism I can think of for viewing available system memory on the cRIO is to use netconsole to get access to the operating system (vxWorks). I'm not sure if netconsole lets you send commands, if it doesn't you can try out this node.js implementation.
Another alternative:
You should also be able to connect over the serial port. follow these steps, using a terminal program like HyperTerminal, or putty.
Connect a null-modem serial cable from your computers serial port to the controller serial port.
Configure a terminal program for 9600 bps, no parity bit, 8 data bits, and 1 stop bit.
Turn the CONSOLE OUT DIP switch on the controller to the ON position and reboot the controller. The terminal will display output and diagnostics during the boot process. When it is finished, the message “Welcome to LabVIEW Real-Time” will print.
Once at vxWorks, use the memShow command to view free/used memory.
More info on vxWorks commands here
http://team2168.org
Unread 30-01-2014, 06:05
Click on the Charts tab of the Driver Station and look over to the right: http://wpilib.screenstepslive.com/s/...ation-software
Unread 30-01-2014, 13:25
otherguy's Avatar
sparkE
AKA: James
Thanks for pointing that out. I didn't see it in the chart when I was looking last night.
http://team2168.org
