Go to Post Ohh the [strike]humanity[/strike] robotity! - artdutra04 [more]
Unread 30-01-2014, 13:50
bachster's Avatar
bachster bachster is offline
AKA: Katie Bach
FRC #2052 (KnightKrawler)
bachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant future
Re: The age old question - bumper mounting
Thanks for the clarification, Nuttyman54. It still seems to me like this doesn't meet the intent of "backed by the FRAME PERIMETER..." as my definition of "backed" would be surface to surface (or perhaps surface to edge). In this arrangement, there is still no part of the bumper wood directly touching the outside edge that defines the frame perimeter (or within 1/4"). Yes, there are bolts/rivets just interior to the frame perimeter holding a bracket in shear, but in my mind that's not the same thing. If the C of the frame was less than 5" tall, such that the wood directly contacted the outside edge which forms the frame perimeter, that would be more obvious to me that it meets R26. (Or even if the C was just a little bit shorter, and the brackets went to the outside rather than the inside, assuming the brackets are less than 1/4" thick).
If I were to speculate on the intent of R26, it would be that if the robot was hit hard in the bumper zone, the bumper would be prevented from moving relative to the robot (or at worst, would only move 1/4") by the wood surface compressing to the frame perimeter. In this example, the wood is prevented from moving inward by the shear strength of the bolts/rivets, not by the rigid frame perimeter. It is perhaps further prevented from moving by the length of the brackets which closely match the depth of the "C", but you could easily have shorter brackets or a deeper "C" and lose that feature. If I was inspecting this design, I would challenge that it meets the intent of the rules.
Thanks for sharing this example of a different form of implementation and rules interpretation. As a robot inspector, I'm interested in making sure I understand how the rules are and should be interpreted prior to the events. I would be interested in any LRIs' thoughts on this.
Katie
