Go to Post Why is it whenever you tell someone there is a million billion stars in the universe they believe you, but if you tell someone that the bench over yonder has wet paint, or if usfirst.org comes up as the 1st result in Google people have to try it for themselves? - artdutra04 [more]
Unread 30-01-2014, 15:25
wildbot3844 wildbot3844 is offline
AKA: James Helton
FRC #3844 (Kentucky Wildbots)
wildbot3844 is an unknown quantity at this point
Digital Switch Problems
Our team has been having issues with digital switches, sometimes when the state of the switch is changed (from TRUE to FALSE or vise versa) the motors on the robot twitch, but the switch has no relation (in the program) to the motors that are twitching, does anyone know how to fix it??
Unread 30-01-2014, 15:59
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Digital Switch Problems
Are these limit switches connected to digital inputs?
Is it possible that they are wired incorrectly and shorting the +/- pins on the digital input port causing the digital sidecar to misbehave?
Brad Miller
Robotics Resource Center
