Go to Post FIRST's awesomeness cannot be described in numbers. - Shinglei [more]
Unread 27-01-2014, 21:57
BEN35678's Avatar
BEN35678 BEN35678 is offline
FRC #1523 (MARS)
BEN35678 is an unknown quantity at this point
Type of Flashlights
We are going to be using a flash light for aiming. What type of flashlight is the best for this?
Unread 27-01-2014, 22:03
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Type of Flashlights
While we have never used a "photon cannon" you want one that that is coherent/bright enough to deal with arena lighting as well as easily adapted to being powered by the PDB all while making it follows all other electrical rules.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 28-01-2014, 07:53
Ben,
Be aware of R8 (it includes the vision of the drivers). If it violates this rule, and other complain, you may be asked to remove it.
Unread 30-01-2014, 16:00
RobotDoktor's Avatar
RobotDoktor RobotDoktor is offline
Cat Herder
FRC #4265 (Secret City)
Team Role: CAD
RobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really nice
Last year 4265 was one of the few teams that used a flashlight for aiming. I believe it was an Ultrafire (Surefire ripoff brand) that we wired to be controlled by the robot. I can check the exact model if you want.
Unread 30-01-2014, 16:03
BEN35678's Avatar
FRC #1523 (MARS)
If you wouldn't mind would you get the model.
Unread 30-01-2014, 16:04
BEN35678's Avatar
FRC #1523 (MARS)
Ben,
Do you think that we would have a problem violating this rule.
Unread 30-01-2014, 21:00
Treadus Treadus is offline
FRC #1987 (Broncobots)
Treadus is an unknown quantity at this point
We used a Streamlight Polytac HP last year for targeting. The HP has a small and bright hot spot with a good throw, making it good for this use. The whole head of the light screws off and it can be wired directly to the regular 5V converter.
For that whole distracting the drivers thing, you can turn the light on and off depending on when you want to aim and shoot. Just set it to a button for momentary on/off. You'll also want to mount any light you pick inside a tube or something to block out the spill so you don't blind opponent drivers under the goal.
Just be responsible with the light and you shouldn't have any issues, but just like others said, others can always complain about the light. We didn't have any problems at the two regionals we attended last year. We found that our photon cannon was way less distracting than those ridiculously bright LED rings.
