Go to Post Swisscheeseafy - Cutting holes in the robot to decrease weight - alithanar8 [more]
Unread 28-01-2014, 14:08
Nazzieg327 Nazzieg327 is offline
FRC #4108
Nazzieg327 is an unknown quantity at this point
Bridge Configuration problem
When trying to configure our bridge using the Bridge Configuration Utility we get the following error : Failed to change IP address.
Our bridge is connected to the computer. All wireless networks have been disabled. We can't seem to find any trouble shooting information for the bridge. Has anyone else had this problem? Thanks
Unread 28-01-2014, 15:47
Re: Bridge Configuration problem
It sounds like you might be running the program from a user account with limited privileges. Try running it as an administrator.
(The other possibility is that your computer is set to a language other than English and is confusing the configuration tool, but that's not likely here.)
Unread 30-01-2014, 16:43
FRC #4108
Thank you for your response. However i am on a admin account and it's definitely in English.
Unread 30-01-2014, 16:52
What brand of computer are you using? Some manufacturers include a "helpful" utility that tries to make network settings "easy" for inexperienced users, and that might be keeping your network interface from being controlled by the configuration tool.
Unread 30-01-2014, 18:13
FRC #4108
We are using a lenovo ThinkPad, running windows 7. Thanks
Unread 30-01-2014, 20:19
Lenovo is one of the manufacturers that uses their own network management software.
