Go to Post At the end of the day, it really isn’t about the awards. - JesseK [more]
Unread 22-01-2014, 10:05
vanamaxagon vanamaxagon is offline
FRC #3145
vanamaxagon is an unknown quantity at this point
Ball shifter assembly
We had trouble assembling our 3 stage Vex ball shifters yesterday.
The washer spacers under the hex standoffs didn't support them properly on the narrow shoulder above the 7/16 hex recess.
When tightened, the standoffs were not square the the face of the gearbox, and were not tall enough to allow the front plate to mount properly.
The kids machined some 7/16 OD x .220" long spacers with a 1/4 hole to seat in the bottom of the 7/16 hex recess and reassembled the gearbox and we are functional now.
Watch out for this.
Unread 22-01-2014, 10:13
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Re: Ball shifter assembly
We are (hopefully, if they come in) going to be assembling ours today, but I am a bit confused, which step in this guide did the problem occur? http://content.vexrobotics.com/vexpr...Instr-Rev1.pdf
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 22-01-2014, 13:56
Aren_Hill's Avatar
Build Nifty Things
Watch out for this.
Martin,
I got your email, and you are correct, we need to update page 9 of This instruction manual To show the washers on the correct side of the standoff. They should be between the standoff and plate.
Thank you for bringing this to my attention.
-Aren
A guy who likes robots.
Unread 25-01-2014, 18:22
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
I didn't want to create a new thread, but we ran into problems today with the assembly of the new 3 CIM ball gearboxes.
The bearing that supports the output side of the output shaft does not fully seat into the plastic housing.
The bearing flange is about .01" bigger in diameter than the bore in the plastic housing. When installed the bearing seems as if it is seated properly, but it is not and you will not be able to assemble the housings together due to this.
We simply carved away some material from the plastic with an Xacto blade to fix the issue.
I've attached photos for reference.
http://www.flickr.com/photos/72773803@N00/12141880874
http://www.flickr.com/photos/72773803@N00/12141888644/
http://www.flickr.com/photos/72773803@N00/12141487335/
Bearing not seated into bore.
http://www.flickr.com/photos/72773803@N00/12142132676/
Bearing seated into bore after carving away some plastic.
http://www.flickr.com/photos/72773803@N00/12141727993/
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 30-01-2014, 09:35
thmeans06 thmeans06 is offline
Drive Coach, IT Support, Mentor
FRC #0066
thmeans06 is an unknown quantity at this point
After assembly, one of our gearboxes seemed to be binding pretty badly. I took it back apart and found that the problem was with the Encoder Gear Assembly.
The little plastic gear with bearing and rod that sits on the outside (back of the gearbox) was bent so that every revolution of the gearbox would cause it to bind on it's housing.
Vex is sending us a new part to replace it.
See the photo attachment if you don't understand what part I am talking about.
Name:	Screen Shot 2014-01-30 at 9.33.22 AM.png
Unread 30-01-2014, 14:08
Aren_Hill's Avatar
Build Nifty Things
Brad,
With a bit more press the bearing should pop right in, it will be updated for the future as that feature does not have a need to be tight on the bearing flange.
-Aren
Unread 30-01-2014, 14:49
AKA: Bradley Rigdon
Originally Posted by Aren_Hill View Post
Brad,
-Aren
I'm sure it could be pressed in, but I don't feel a .007" or so press fit would be a wise idea especially into plastic. I would not want to see a crack develop especially in that area of the housing. The other bearings fall into place so it was abnormal to have to press in only one of the four internal bearings. This bearing does fall into place like the others until it gets to the flange and on the first attempt of assembling them it seemed right until the housings didn't fit together without a gap since the bearing wasn't fully seated.
Unread 30-01-2014, 15:14
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Brad,
-Aren
We used are manually press and with little effort it pressed right in.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 30-01-2014, 15:17
Mentor,QCR Planning
We ran into a problem that when we went to mount the gearbox utilizing the 1/4-20 nylocks on one of the sides onto our test base, the bolt cracked the plastic behind the nut. When we went to investigate the nut fell out of place. We aren't sure if this has compromised the gearbox housing or not. For other reasons we have switched gearboxes and have not taken them apart to look into it more.
Unread 30-01-2014, 15:27
Aren_Hill's Avatar
Build Nifty Things
Jimmy,
If you use screws that are too long that would happen, The integrity of the case itself is still intact.
-Aren
Unread 30-01-2014, 16:53
Mentor,QCR Planning
Jimmy,
-Aren
We thought we had the right length.
Thanks
