Go to Post "Mentors Only Work When Being Calibrated". - Calvin Hartley [more]
Unread 30-01-2014, 16:57
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Re: Ball Shifter coupling not together??
It is a super tight tolerance, I have tried again and I do not believe that I have it right...can you provide a picture of how yours looks before you place the top clamp on the shaft?
Thanks
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 30-01-2014, 17:20
Aren_Hill's Avatar
Build Nifty Things
Thanks
Sorry for the quality, I just have my phone handy.
The Nut and the flats on the piston must line up.
-Aren
A guy who likes robots.
Unread 30-01-2014, 18:43
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Ours lined up. You have to have the nut nearly flush with the end of the threads.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 30-01-2014, 19:04
Aren_Hill's Avatar
Build Nifty Things
This is intended, as it sets the spacing for the piston to plunger attachment to make sure the mechanism works correctly.
Unread 30-01-2014, 20:35
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Hey we encountered one more problem Aren, The standoffs for the 3rd stage are not 1"....more like 1 7/8"...so they stick out farther, the gear and bearing no longer are contained and will need to have a spacer made to keep them on. The bigger problem is our belly pan that was machined based on specs and now we will have to cut belly pan to fit the shifters in.
Unread 30-01-2014, 20:47
Chris is me's Avatar
AKA: Pinecone
It seems like you ordered the WCD version of the shifter instead of the regular version. The WCD one has longer standoffs so that you can put sprockets, belt pulleys, etc. inside.
Disclaimer: I obviously know way less about this than Aren does, I don't work at Vex.
Unread 30-01-2014, 20:53
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Correct, We did order the WC one...those are the instructions I am reading...that is why I am so confused.
Unread 30-01-2014, 22:33
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Nm. Managed to look over the important detail of sprockets being put in place..that quickly closes the gap. Thank you for turning on the light bulp!
Thanks, Ronnie.
