Go to Post ...Well also I'm just hooked on FIRST. (I swear, I can quit whenever I want!) - CENTURION [more]
Unread 30-01-2014, 17:07
Matt Files Matt Files is offline
FRC #4908
Matt Files is an unknown quantity at this point
Are Norgren Regulators Required?
We ordered a regulator using our first choice credits, it is not a Norgren but it is a Monnier. We heard from another team that only the Norgren Valves are allowed. Is this true?
Unread 30-01-2014, 17:12
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
Re: Are Norgren Regulators Required?
The answer to that question is in the manual
4.10.9 R82
“Working” air pressure on the ROBOT must be no greater than 60 psi and must be provided through one primary
adjustable, relieving, pressure regulator.
Norgren regulator P/N: R07-100-RNEA recommended.
The rules simply require a regulator, the blue box recommends a specific one.
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 30-01-2014, 17:13
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
It doesn't appear to be required, only recommended. From the manual
“Working” air pressure on the ROBOT must be no greater than 60 psi and must be provided through one primary adjustable, relieving, pressure regulator.
Edit:Ninja'd
Unread 30-01-2014, 17:53
The important part of the that reference is the "relieving" regulator. This allows high pressure on the working side to be vented to atmosphere when it is greater than 60 psi. Other regulators are allowed if the primary regulator meets the specifications.
