Go to Post what would we do without brandon? - Arefin Bari [more]
Unread 30-01-2014, 18:13
Q Branch 4327's Avatar
Q Branch 4327 Q Branch 4327 is offline
FRC #4327
Q Branch 4327 is an unknown quantity at this point
Fans are no longer working
We had 6 fans hooked up on our robot. 4 on Talons, 2 on Victors. They appear to have burnt out, but we don't know why. The wiring is correct, and we tried powering it directly by a battery and still nothing. Any suggestions?
Unread 30-01-2014, 19:16
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Re: Fans are no longer working
Do the speed controllers still work?
If so, have you touched them while they were running?
Unread 30-01-2014, 20:41
FRC #4327
The speed controllers do still work, and I haven't touched them while running because they always had the fans on them.
Unread 31-01-2014, 11:53
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
I would check the voltage rating on the fans and make sure they are rated for 12 volts.
I hope you had the fans powered from input side of the speed controller and not motor side. Just one of those things to check.
