Go to Post We are making this up as we go along - please don't confuse us by telling us the way that it really should be done. - dlavery [more]
Unread 30-01-2014, 18:14
Crzycoco Crzycoco is offline
Co-Capt.
Rookie Year: 1234
Crzycoco is an unknown quantity at this point
Lightbulb Is getWatchdog() required in RobotTemplate.java?
I was wondering if we HAVE to have getWatchdog() in our code or is it optional. I know it prevents the robot from malfunction but I don't know if it's required. Thanks guys, FIRST rules!
Unread 04-02-2014, 19:18
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
Re: Is getWatchdog() required in RobotTemplate.java?
Would also like to know. Thanks to anyone who has the info.
Unread 04-02-2014, 19:21
No. If you do not know what the watchdog is or how to use it properly I recommend you avoid it.
Unread 10-03-2014, 01:30
MatthewC529 MatthewC529 is offline
Lcom/mattc/halp;
AKA: Matthew
FRC #1554 (Oceanside Sailors)
MatthewC529 is on a distinguished road
I personally use Watchdog.getInstance() in my code.
Watchdog scruffy = Watchdog.getInstance(); //for instance
getInstance() is a common method provided in Singleton classes or classes that are mean to NOT be instantiated. A good example is the Math class in Java SE 7 (Does not have getInstance()... meaning "REALLY do not get this instance"). Another example is the Java SE 7 Toolkit class which some games use for getting the screen width of your computer. It has a method called Toolkit.getDefaultToolkit() which might as well be Toolkit.getInstance().
That method ensures only ONE instance of the class EVER exists. You wouldnt want two logging classes posting to the console (in most cases) so you make it a singleton with getInstance() capability. Only one Watchdog will EVER exist. That is all that means.
You can freely use getInstance to have your own reference to the Watchdog object just so you are familiar. Like mine is named Scruffy.
