Go to Post I think that FIRST should just give up and officially recognize Chiefdelphi as the place to go for community and team resources. - Greg Needel [more]
Unread 30-01-2014, 17:40
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Issue with Servo and Motor Program
I am a beginner, first year programmer and I wrote a couple programs in CommandBase java and they have a few errors. I do have the robot driving.
One of them was supposed to have two commands defined by a subsystem - one command would move a servo 45 degrees away from its default location and the second one would move the servo back to its default location. When I press the buttons assigned to complete these tasks nothing happens.
Here it is:
Subsystem(called LaunchServo):
package edu.wpi.first.LFRobot2014.subsystems;
import edu.wpi.first.LFRobot2014.RobotMap;
import edu.wpi.first.wpilibj.Servo;
import edu.wpi.first.wpilibj.command.Subsystem;
* @author FrankyMonezz
public class LaunchServo extends Subsystem {
// Put methods for controlling this subsystem
// here. Call these from Commands.
Servo servo = new Servo(RobotMap.LaunchServoPort);
public void initDefaultCommand() {
// Set the default command for a subsystem here.
//setDefaultCommand(new MySpecialCommand());
public void setPos(double pos){
servo.set(pos);
public double getPos(){
double pos = servo.get();
return pos;
Command to Move it to 45(called PrepBall):
package edu.wpi.first.LFRobot2014.commands;
public class PrepBall extends CommandBase {
public PrepBall() {
// Use requires() here to declare subsystem dependencies
// eg. requires(chassis);
requires(launchservo);
// Called just before this Command runs the first time
protected void initialize() {
// Called repeatedly when this Command is scheduled to run
protected void execute() {
//move servo to 45 degrees
launchservo.setPos(45);
// Make this return true when this Command no longer needs to run execute()
protected boolean isFinished() {
if(launchservo.getPos() == 45){
return true;
else {
return false;
// Called once after isFinished returns true
protected void end() {
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
protected void interrupted() {
Command to Move back to Default(called PrepBall2):
public class PrepBall2 extends CommandBase {
public PrepBall2() {
//move servo back to default location
launchservo.setPos(0);
if(launchservo.getPos() == 0){
return true;
else {
return false;
Port Assignment:
public static final int
LaunchServoPort = 5;
CommandBase(subsystem is called LaunchServo):
public abstract class CommandBase extends Command {
public static OI oi;
// Create a single static instance of all of your subsystems
public static ForkMotor forkmotor = new ForkMotor();
public static ArmMotor armmotor = new ArmMotor();
public static Chassis chassis = new Chassis();
public static LaunchServo launchservo = new LaunchServo();
Button Assignments(PrepBall - moves it to 45 -- PrepBall2 - moves it to default):
public Joystick
rightStick,
leftStick;
private final Button ForksDown, ForksUp, prepball, prepball2, motor1, motor2; //add Auto
public OI() {
rightStick = new Joystick(RobotMap.rightJoystickPort);
leftStick = new Joystick(RobotMap.leftJoystickPort);
ForksDown = new JoystickButton(rightStick, 5);
ForksUp = new JoystickButton(rightStick, 4);
prepball = new JoystickButton(leftStick, 4);
prepball2 = new JoystickButton(leftStick, 5);
motor1 = new JoystickButton(rightStick, 2);
motor2 = new JoystickButton(rightStick, 3);
//Auto = new JoystickButton(leftStick, 4);
ForksUp.whileHeld(new LiftForks());
ForksDown.whileHeld(new LowerForks());
prepball.whenPressed(new PrepBall());
prepball2.whenPressed(new PrepBall2());
motor1.whenPressed(new ArmLauncher());
motor2.whenPressed(new ReleaseTension());
//Auto.whenPressed(new AutoCommandGroup());
public Joystick getRightStick() {
return rightStick;
public Joystick getLeftStick() {
return leftStick;
The other one had two commands defined by a subsystem called ForkMotor. One command was supposed to move a motor forward(1) while a button was pressed. The other was supposed to move a motor backwards(-1) while a button is pressed. When I hold the button down that is supposed to move it forward the motor glitches off and on but does stop when I let go - the motor is fine I tested it. The button that SHOULD turn it in the other direction doesn't work at all
Here it is:
Subsystem(called ForkMotor):
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.SpeedController;
public class ForkMotor extends Subsystem {
SpeedController motor = new Jaguar(RobotMap.ForkMotorPort);
public void up() {
motor.set(1);
public void down() {
motor.set(-1);
public void stop(){
motor.set(0);
First Command(to move it forward -- called LiftForks):
public class LiftForks extends CommandBase {
public LiftForks() {
requires(forkmotor);
setTimeout(.5);
forkmotor.up();
return isTimedOut();
forkmotor.stop();
end();
Second Command(to move it in reverse -- called LowerForks):
public class LowerForks extends CommandBase {
public LowerForks() {
setTimeout(.5);
forkmotor.down();
forkmotor.stop();
end();
Port Assignment(called ForkMotorPort):
leftMotorPort = 1,
rightMotorPort = 2,
ArmMotorPort = 3,
ForkMotorPort = 4;
CommandBase(called ForkMotor):
Button Assignments(LiftForks - moves it forward(1) -- LowerForks - moves it in reverse(-1):
public Joystick
rightStick,
leftStick;
public OI() {
return rightStick;
return leftStick;
ANY help WILL be appreciated - THANKS!
Unread 30-01-2014, 18:33
Re: Issue with Servo and Motor Program
Did you install the 6v jumper on the digital sidecar so that the servo gets power?
Unread 30-01-2014, 18:48
LFRobotics's Avatar
FRC #4623
Oh - no I did not - other than that is the servo program good - also netbeans states that the if statement that I use is redundant - what does it mean by this?
Why do you think the motor program will not work?
THANKS!
Unread 30-01-2014, 18:56
Which if statement?
Unread 30-01-2014, 19:30
LFRobotics's Avatar
FRC #4623
The
return true;}
else {
return false;}
and the other one that has a 0 in place of the 45. - It's in the isFinished() methods of the two servo commands - its what SHOULD shut them off when they reach their position.
THANKS!
Unread 30-01-2014, 19:32
It's telling you that the code you posted is the same as the following:
return (launchservo.getPos() == 45);
It's not an error, but just a way to help you make the code simpler.
Unread 30-01-2014, 19:44
LFRobotics's Avatar
FRC #4623
Okay - I will change that - but other than that the servo code is good - and what about the motor code?
THANKS!
