Go to Post Remember; FIRST is staffed by real live humans, some of whom have a sense of humor. - Andy A. [more]
Unread 30-01-2014, 19:02
ninjabaker2395 ninjabaker2395 is offline
NINJAbaker
FRC #2395 (the 4H NINJA MUNKEES)
ninjabaker2395 is an unknown quantity at this point
Re: Window Motor will not lift ball anymore. It did, but it wont any more.
Originally Posted by ShaneKent253 View Post
Hello from team 253!
We have a window motor lifting a claw that extends out of our frame roughly 19". Last week it worked fine running directly off of a spike and now we just cant get the claw to lift even though we haven't changed a single thing.
I don't know what to do and I am feeling a lot of stress about the situation. Any help would be appreciated.
Thank you!
Shane
Pictures coming.
from what you described it sounds like you stripped the main gear of the motor. The same happened to my team2395 in 2012 on our bridge manipulator. You either have to change out the gear or replace the entire window motor, but that will be a temporary fix because it will strip again if you don't change the way in which you rotate the shaft.
