Go to Post Stupid rules are not meant to be broken; they're meant to be changed. Unless and until they are changed, breaking them is wrong. - Alan Anderson [more]
Unread 29-01-2014, 22:49
StylesOfKimchi StylesOfKimchi is offline
FRC #2785
StylesOfKimchi is an unknown quantity at this point
cRIO Imaging Issues
As a team, we have 2 cRIO's. One of the small 4 slot ones and one of the larger, 8 slot ones.
The 4 slot one worked fine and it formatted and reimaged without any issues.
However, after we took it off and switched it with the 8 slot one, I was unable to reimage the cRIO.
I used the imaging tool and the display box went through the steps, formatting the cRIO, then rebooting it.
(Not quite sure if I'm remembering correctly that it was at this message, but) at this step, it just froze on the "rebooting cRIO" message and stopped working.
Has anyone else had this issue and been able to resolve it?
Thanks in advance.
Unread 29-01-2014, 22:59
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: cRIO Imaging Issues
How was your imaging PC networked to the crio? directly over ethernet cable, through a switch/bridge/router, wifi?
When directly wired to the cRIO: Some computers don't play nice when the network connection goes away while the crio is rebooting.
I suggest following this guide if you haven't already:
http://wpilib.screenstepslive.com/s/...ging-your-crio
http://team2168.org
Unread 30-01-2014, 19:03
FRC #2785
The cRIO was connected directly to the lab top through an Ethernet cable.
I tried formatting and loading the 2014 image various times, however I kept getting stuck st the same point mentioned in my first post.
I don't think its an issue with the computer as it loaded the 2014 image onto one of the cRIOs without any issue
Unread 02-02-2014, 23:48
MikeShi MikeShi is offline
FRC #0867
MikeShi is an unknown quantity at this point
I had the same issues and I resolved it by flipping the "IP Reset" DIP switch on the cRIO.
Unread 03-02-2014, 14:45
Lippseric Lippseric is offline
FRC #4284
Lippseric is an unknown quantity at this point
We are having the opposite issue: the 4-slot cRIO locks up when we have tried to re-image it, and the reset switch is not available on that model. Does anyone have any other advice?
Unread 03-02-2014, 14:47
Fot the 4-slot cRIO, turning the Console Out switch off on the cRIO Imaging Tool display can sometimes help.
To reset the 4-slot hold the physical rest button on the front of the cRIO down for about 10 seconds. The yellow status light will flash when it resets and you can let go.
