Go to Post OMG this topic again. Those who stir the pot should lick the spoon. - nuggetsyl [more]
Unread 30-01-2014, 19:15
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Window Motor will not lift ball anymore. It did, but it wont any more.
Originally Posted by ShaneKent253 View Post
In a no load application where we are only lifting our arm assembly without the ball the motor works fine. Only when we try to lift with the ball does the window motor not work.
Any ideas?
The window motor has an internal thermal breaker in it which opens to prevent the motor from burning out. It appears that you have the motor attached directly to the pivot of the arm. This will place a large load on the motor. When the ball is added, the motor stalls, and the internal breaker trips.
Try using a different motor, and using a gear/chain/belt reduction before the arm.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
