Re: Window Motor will not lift ball anymore. It did, but it wont any more.
No, but I have heard about this. Can you explain what this would do for us?
You definitely can't get away with directly driving an arm with a window motor. You need a reduction of some kind.
If you can make pneumatics work for you, I would suggest that simply because it's much easier to accomplish and simpler than a motor driven arm system. |
A window motor is just not going to get the job done here. You are experiencing what happens when you try direct drive. But if you gear it down it will be too slow to shoot the ball.
If you look at the motor data sheet for this year you will find that the window motor is comparatively low power. You need to find a different basic way to operate your arm using a more powerful motor. |
The window motor's max output is 23W, with is quite a bummer considering there are only a few motors weaker than it, and most motors are a LOT more powerful: http://www.usfirst.org/sites/default...nformation.pdf Like others have mentioned, it would be a really good idea to use a better/bigger motor. |
The breaker was added to stop the finger breakage, the locking pins mean a thief cant just force the window down. When its not powered, they are locked.
#7
Also, is the indicator light on your Spike changing color when you attempt to move it?
Could be a loose/bad/wrong way PWM, program change, etc. If the indicator is turning red/green, then you know the relay is working. |
#8
Could you maybe reduce the stress by putting a window motor on both sides of the arms? I would think using 2 window motors would help a lot, but i might be mistaken.
#9
Doubling up window motors might end up with a worse problem. If one of them runs just a little faster than the other, they'll start fighting each other, and the anti-backdrive feature is likely to lock one of them up. If you don't need the motors to actively hold their position against a force trying to move them, it might be best to open them up and remove the pins.
This application probably calls for a stronger motor, though. It's a good opportunity to do the math and find out what torque is required at what speed, then match that to an available motor and gearbox. |
#10
Try using a PG motor or a versa planetary.....Window motors are that good
#11
Given the amount of COTS options compared to several years ago, however, we will never use them again for a similar purpose because it doesnt backdrive after a match. If OP is set on using a window motor, put a reduction AND use another window motor. |
#12
No matter what motor you end up using, the first thing you can do to help yourselves is to add a spring to counter balance the weight of your arm. This could be as simple as a piece of surgical tubing wrapped around a pulley that's attached to your arm pivot axis. Attach the other end of the surgical tubing to your frame so that the weight of the arm is supported by the stretched tubing, not your motor. Then, the motor just has to handle arm motion, not carry the weight.
Properly counterbalanced, a window motor just MIGHT work. But, the teams at our last FRC summit concluded that window motors are supplied as object lessons for rookie teams to learn what NOT to use. Most of us just throw them in the trash. With their limited capabilities, there are much better options available. Not to mention that the thermal cutoff will kick in at the most inopportune moment, leaving you motionless until the motor cools down. |
#13
To remind everyone, the locking pins in these motors are really only an issue when driven by Jaguars. There is a lot of discussion about this in the files. It was first brought to our attention by John Novak from Team 16.
I like Todd's suggestion, so you can check if the motor is defective or just being asked to do too much (which we all suspect now that we have seen the assembly). The motor does have a thermal cutout (a PTC as I remember) but that is usually backed up by a hot motor casing. |
#14
Don't take that to mean that the window motor is the correct choice for this application, though. The throttle motors, on the other hand.... |
#15
I completely agree with Mr. Lavery about the window motors not being useless. We have certainly burned out our fair share of them when we were stretching their capabilities, but in the correct applications they can be very useful. The hubs alone can make them useful for some applications, as they are easy to mount things to without significant machining capabilities. Add the worm gear and they can be used in a variety of ways, as long as you aren't trying to put too much load on them. As Mr. Ferrante said, counterbalancing the load with a spring of some sort can help a lot. Here is an application of this sort of counterbalancing.
