Go to Post Even worse, you could have a "Kiss the Paul" contest. I heard he squeals when you pick him up too. - AndyB [more]
Unread 30-01-2014, 18:28
ShaneKent253 ShaneKent253 is offline
FRC #0253
ShaneKent253 is an unknown quantity at this point
Window Motor will not lift ball anymore. It did, but it wont any more.
Hello from team 253!
We have a window motor lifting a claw that extends out of our frame roughly 19". Last week it worked fine running directly off of a spike and now we just cant get the claw to lift even though we haven't changed a single thing.
I don't know what to do and I am feeling a lot of stress about the situation. Any help would be appreciated.
Thank you!
Shane
Pictures coming.
Unread 30-01-2014, 18:33
Chris is me's Avatar
AKA: Pinecone
Re: Window Motor will not lift ball anymore. It did, but it wont any more.
Are you gearing the arm directly to the window motor? This is bad bad bad. You need at the very least a healthy sprocket reduction.
When we used window motors on our 2011 arm, even with a reduction and counterbalancing the motors would wear out about once per regional. Basically they would get very hot and then just stop working like yours seems to have. I would not do a window motor arm again unless it was very short and / or a ton of reduction was added to the motor.
With the high number of COTS gearboxes that are available to accomplish high reductions, you have a number of other options to consider that use a higher power motor more safely. You will likely need to combine products (e.g. a VersaPlanetary + a spur gearbox) but it's very doable.s
Unread 30-01-2014, 18:47
FRC #0253
Here is a picture of our motor. This motor is brand new and it still wont work again. Can you think if there is any reason that a brand new motor wont work any more?
Thanks.
Unread 30-01-2014, 18:53
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Does the motor still spin in a no load application? (Not having to lift the entire arm assembly?)
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 30-01-2014, 19:02
ninjabaker2395 ninjabaker2395 is offline
NINJAbaker
FRC #2395 (the 4H NINJA MUNKEES)
ninjabaker2395 is an unknown quantity at this point
Thank you!
Shane
Pictures coming.
from what you described it sounds like you stripped the main gear of the motor. The same happened to my team2395 in 2012 on our bridge manipulator. You either have to change out the gear or replace the entire window motor, but that will be a temporary fix because it will strip again if you don't change the way in which you rotate the shaft.
Unread 30-01-2014, 19:07
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Does the motor make any noise at all? Did you burn out the 20A fuse in the Spike?
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 30-01-2014, 19:09
FRC #0253
The fuse is brand new and so is the window motor.
Unread 30-01-2014, 19:11
FRC #0253
In a no load application where we are only lifting our arm assembly without the ball the motor works fine. Only when we try to lift with the ball does the window motor not work.
Any ideas?
Unread 30-01-2014, 19:15
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Any ideas?
The window motor has an internal thermal breaker in it which opens to prevent the motor from burning out. It appears that you have the motor attached directly to the pivot of the arm. This will place a large load on the motor. When the ball is added, the motor stalls, and the internal breaker trips.
Try using a different motor, and using a gear/chain/belt reduction before the arm.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 30-01-2014, 19:24
FRC #0253
Would it be plausible to use a pnuematic piston on a cam system. By my knowledge it wouldn't have to be a large piston, it would just have to apply enough force to lift the ball.
Unread 30-01-2014, 19:28
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
Did you take the internal safety lock pins out?
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 30-01-2014, 19:29
FRC #0253
No, but I have heard about this. Can you explain what this would do for us?
Unread 30-01-2014, 19:31
Chris_Ely's Avatar
AKA: luckof13
Would it be plausible to use a pneumatic piston on a cam system. By my knowledge it wouldn't have to be a large piston, it would just have to apply enough force to lift the ball.
That could be possible. It depends on what you are trying to do. A pneumatic cylinder only has two positions, in and out. If that is all you need, then it could work. You will have to do the calculations to determine how large a cylinder you need.
Unread 30-01-2014, 19:55
nicholsjj's Avatar
AKA: John Nichols
http://www.chiefdelphi.com/media/papers/2685? This is a paper on how to take them out. From my limited understanding of what happens is that they will lock the system up if they are put under too much stress, such as lifting a heavy arm. This is added to them as a saftey feature so that children or adults do not break their fingers in a jamed car window I think. We had trouble at first with them last year as we used 4 windowmotor gearboxes for our climber. If you arm is lifiting and then all of a sudden stops then I would look into taking them out. It is legal to do still by R30 in the rules. If you are still having problems you can machine out another motors output shaft and attach it to the window motor gearbox leagly per Q&A 243.
Unread 30-01-2014, 20:39
AKA: Pinecone
You definitely can't get away with directly driving an arm with a window motor. You need a reduction of some kind.
If you can make pneumatics work for you, I would suggest that simply because it's much easier to accomplish and simpler than a motor driven arm system.
