Go to Post but eventually it seems that we realize that there's an I in FIRST, and the I stands for Inspiration, not for "me" - MrForbes [more]
Unread 30-01-2014, 19:46
rdoglivin rdoglivin is offline
FRC #4976
rdoglivin is an unknown quantity at this point
robot turns to the left?
hey i'm part of a rookie team 4976. our bot seems to turn to the left when driving forward but going back it moves to the right. we have discovered it is not a mechanical problem by switching the motors and motor controllers. so i was just wondering if any older teams have experienced this problem before what or could it be? We have as well checked voltage all were 12.04v when moving straight Thanks
Unread 30-01-2014, 20:03
mklinker's Avatar
mklinker mklinker is offline
Coach FRC4485
AKA: Mike Klinker
FRC #4485 (Tribe Tech Robotics)
mklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to behold
Re: robot turns to the left?
Four motors or two? If 4 one motor may not be getting power and/or PWM signal. Check for a reversed PWM cable.
Mike Klinker Mentor, Tribe Tech Robotics FRC 4485
2016 Walker Warren District Semi-Finalist
2015 Indiana District Championship Semi-Finalist, Purdue District Quarter Finalist, Kokomo District Quarter Finalist, R2OC Finalist
2014 Boilermaker Regional Quarter Finalist
Unread 30-01-2014, 20:04
KingRandy's Avatar
KingRandy KingRandy is offline
King_Randy
AKA: Randy
FRC #4567 (RoboVikings)
KingRandy will become famous soon enoughKingRandy will become famous soon enough
We had that problem last year and it was caused by a pinched bearing. Double check your bearings as well as your spacers (Spacers were too tight for us). Also you may need to calibrate your motor controllers. Based on our controllers (Vex Victors)... you need to push the small pin near the heat sink until the lights start flashing (red or green I believe) and then drive Up 5 seconds, down 5 seconds, right 5 seconds and left 5 seconds. Hoped that helped, PM me if you need further assistance.
2013-Rookie All-Star at SBLI-Long Island Regional
2013-Top Seeded Rookie at SBLI-Long Island Regional
2013-National Championship - Galileo Division
2014 - SBPLI Regional
Unread 30-01-2014, 20:16
FRC #4976
Four motors,we found out the arcade drive is the problem by switching outputs on the side car from 1,2,3,4 to,4,3,2,1 and the problem switched so the bot turns to the right going forward and the left going back does any one have experience with arcade drive not working any suggestions?
Unread 30-01-2014, 20:33
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
When you say to the robot is moving right while moving the joysticks going forward, do you mean the robot is spinning in place?
If so it might be a good idea to try switching motor polarities on two of the jaguars that control the same side of the robot. (i.e. swap polarities at the jaguar on the two motors that drive the left side of the robot, and then see the response from the robot)
Informing us of what the jaguar indicator lights do while you are moving forward may help us diagnose with you as well.
2014 Attended: NYC Regional, SBPLI Regional NYC Regional- Imagery Award in honor of Jack Kamen
2013 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- Gracious Professionalism Award sponsored by Johnson & Johnson,SBPLI Regional- #4 Alliance Captain & Regional Winner- With our impeccable alliance 358 and 3171
2012 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- #7 Ranked Seed & Semi-Finalists, SBPLI Regional- #3 Seed & Regional Winner- With our very awesome alliance 527 and 870, Industrial Design Award sponsored by General Motors
2011 Attended: NYC Regional, SBPLI Regional SPBLI Regional- Xerox Creativity Award and #5 Alliance Captain
2009 Attended: NYC Regional, FIRST Championships NYC Regional Winner- With our amazing alliance 1807 and 56
Unread 30-01-2014, 20:36
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
If you are doing this, make sure your motors aren't fighting each other in the gearbox. Be absolutely sure when you do this that the two motor controllers controlling the motors in one gearbox are flashing the same color light. If you have motors working against one another, it can trip the overcurrent protection in the controllers and have symptoms of what you are describing.
I'm right 90% of the time, so why worry about the other 3%?
Unread 30-01-2014, 21:38
Are you sure you're not accidentally commanding the robot to turn? Using a single joystick for Arcade Drive, it's very hard to control forward and backward without getting a tiny bit of X-axis involved at the same time.
Unread 30-01-2014, 21:44
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
Are you inverting any of the motors? In a normal wheel setup, going forward is different for the wheels on each side.
When you turn left, the left wheels are going backward and the right wheels are going forward. So I would assume that because that is happening when you drive forward, you need to invert the left wheels.
In java this is as simple as:
RobotDrive.setInvertedMotor(RobotDrive.m_frontLeft Motor , true);
RobotDrive.setInvertedMotor(RobotDrive.m_rearLeftM otor , true);
Unread 30-01-2014, 23:03
FRC #4976
Thanks to all who responded, we will try all of the ideas desperate to get this thing moving. I'll give an up date Saturday on what we did (hopefully fixing it) thanks for the ideas!
Unread 31-01-2014, 08:26
R,
Be sure that your speed controllers are calibrated as well. This method causes the controllers to interpret the joystick for full throttle forward and reverse. A good indication that you need this is that the motors creep when the robot is lifted off the floor. Another quick check while you have the robot up is to command it to full throttle forward and check the indicators on your speed controllers. They should all reach full and all at approximately the same joystick position. Repeat for full throttle reverse.
