Go to Post Success is making a difference. - SlamminSammy [more]
Unread 30-01-2014, 19:59
adlasa's Avatar
adlasa adlasa is offline
President and Lead Programmer
AKA: Sasha
FRC #1458 (Red Ties)
adlasa has a spectacular aura aboutadlasa has a spectacular aura aboutadlasa has a spectacular aura about
How long does it take to fill air tanks?
How long does it take to fill a 30.5 in^3 air tank at 120 psi using the
1.03cfm air compressor?
What's confusing is the cfm is only given at 0psi.
Computers run on smoke. When the smoke escapes the computers stop working.
Unread 30-01-2014, 20:40
CRITICALThinker's Avatar
CRITICALThinker CRITICALThinker is offline
New user, first time FRC
FRC #5064 (Opcom Robotics)
Team Role: Electrical
CRITICALThinker is an unknown quantity at this point
Re: How long does it take to fill air tanks?
According to my math .13 gal (30.5 in^3) * 83 sec (1min 26sec as per site)/.5 gal = 21.58 sec to fill to 120 psi.
Unread 30-01-2014, 21:05
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
In competition you will almost never have to fill the tanks from empty though. You should pre-charge them before a match to be sure you have air pressure at start up and also so you won't be running the compressor non-stop. We generally tether up and run ours while in que to be sure that we are topped off.
Even so, the best way to know is to hook up your compressor and run it until you hit 120 psi. Every compressor is a little bit different, some are new, some are old, some are well cared for, others abused. The best way to know how long it takes for your compressor to fill a tank is to fill a tank with your compressor.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
