Go to Post I think the winning robot will be the same as every other year, a robot that is excellent at ONE thing. - Kel D [more]
Unread 30-01-2014, 20:47
Chris is me's Avatar
AKA: Pinecone
Re: Ball Shifter coupling not together??
Originally Posted by Ronnie314 View Post
Hey we encountered one more problem Aren, The standoffs for the 3rd stage are not 1"....more like 1 7/8"...so they stick out farther, the gear and bearing no longer are contained and will need to have a spacer made to keep them on. The bigger problem is our belly pan that was machined based on specs and now we will have to cut belly pan to fit the shifters in.
It seems like you ordered the WCD version of the shifter instead of the regular version. The WCD one has longer standoffs so that you can put sprockets, belt pulleys, etc. inside.
Disclaimer: I obviously know way less about this than Aren does, I don't work at Vex.
