Go to Post It is hard to write code that conforms to a standard that isn't published... - AustinSchuh [more]
Unread 30-01-2014, 10:43
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Ball Shifter coupling not together??
We were assembling our ball shifters and I noticed that the coupling that links the pneumatic cylinder to the shifting linkage does not completely close over both half's flat...where the screws go, it is nice and together but on the end there is a smaller gap, haven't put load on it yet to see if it would be okay but thought I would ask you guys and see if anyone else has had a similar problem.
Thanks, Ronnie.
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 30-01-2014, 10:48
Aren_Hill's Avatar
Build Nifty Things
Re: Ball Shiter coupling not together??
Thanks, Ronnie.
Ronnie,
When properly assembled the coupler sides close flat together, be sure that the nut on the piston shaft is properly seated in the coupler (a flat face on the nut must be parallel to the wall of the recess in the coupler, otherwise there will be a split when assembled due to the nut not being fully seated).
-Aren
A guy who likes robots.
Unread 30-01-2014, 10:57
mspoerk mspoerk is offline
FRC #2062
mspoerk is an unknown quantity at this point
Re: Ball Shifter coupling not together??
We had that same problem. First, I thought it was students being careless. Then a mentor did the same thing. We ended up printing a few on the 3D printer. I increased tolerance on the nut by about .003. Seems to fit nice. We haven't load tested them yet. That's tonight.
Unread 30-01-2014, 11:05
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Hmmmm. My team encountered same problem and solution. Our lead mentor (a real genius at design) noticed that original coupler tolerances for nut and bearing appeared off.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 30-01-2014, 13:41
President, VEX Robotics, Inc.
We have looked at hundreds of couplers here. Are you certain the nut is properly oriented? When the nut is properly rotated, the coupler fits on nice a snug.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 30-01-2014, 16:57
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
It is a super tight tolerance, I have tried again and I do not believe that I have it right...can you provide a picture of how yours looks before you place the top clamp on the shaft?
Thanks
Unread 30-01-2014, 17:20
Aren_Hill's Avatar
Build Nifty Things
Thanks
Sorry for the quality, I just have my phone handy.
The Nut and the flats on the piston must line up.
-Aren
Unread 30-01-2014, 18:43
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Ours lined up. You have to have the nut nearly flush with the end of the threads.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 30-01-2014, 19:04
Aren_Hill's Avatar
Build Nifty Things
This is intended, as it sets the spacing for the piston to plunger attachment to make sure the mechanism works correctly.
Unread 30-01-2014, 20:35
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Hey we encountered one more problem Aren, The standoffs for the 3rd stage are not 1"....more like 1 7/8"...so they stick out farther, the gear and bearing no longer are contained and will need to have a spacer made to keep them on. The bigger problem is our belly pan that was machined based on specs and now we will have to cut belly pan to fit the shifters in.
Unread 30-01-2014, 20:47
Chris is me's Avatar
AKA: Pinecone
It seems like you ordered the WCD version of the shifter instead of the regular version. The WCD one has longer standoffs so that you can put sprockets, belt pulleys, etc. inside.
Disclaimer: I obviously know way less about this than Aren does, I don't work at Vex.
Unread 30-01-2014, 20:53
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Correct, We did order the WC one...those are the instructions I am reading...that is why I am so confused.
Unread 30-01-2014, 22:33
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Nm. Managed to look over the important detail of sprockets being put in place..that quickly closes the gap. Thank you for turning on the light bulp!
Thanks, Ronnie.
