Go to Post I read every darn page of this thread. - Paul Copioli [more]
Unread 30-01-2014, 21:46
JML's Avatar
JML JML is offline
Jlyon
AKA: Jlyon
FRC #3044 (0xBe4)
JML is an unknown quantity at this point
FRC cRIO imaging errors
We connected the cRIO to the pc, and opened the imaging tool. The Imaging tool, however would not recognize the modules that were plugged into the cRIO. We proceeded to run the imaging tool with the java image for this year, and got this error:
Error 15426 occurred at FTP
I have looked up this error, and could not find any solution. I checked, and my network settings are correct, and the laptop can see the cRIO, just not the modules. I am running windows 8.1 as well, any help would be appreciated. Thanks in advance
Unread 30-01-2014, 22:01
droswell's Avatar
droswell droswell is offline
FRC #2370 (iBots)
droswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to behold
Re: FRC cRIO imaging errors
Is your firewall on? Start by turning that off. Make sure you are wired to eliminate and wireless issues. Make sure your ethernet cables are good.
If it's a cRIO you've used before, it should have the IP still. Try pinging it. See if you have comms.
Unread 30-01-2014, 22:03
http://digital.ni.com/public.nsf/all...256EEA00062591 might be relevant. It suggests that you might have both a wired and wireless connection active at the same time.
Unread 31-01-2014, 09:54
JML's Avatar
JML JML is offline
Jlyon
AKA: Jlyon
FRC #3044 (0xBe4)
Thanks for the responses, i will check my wireless settings tonight. I know i had previously been connecting wirelessly. This is a new cRIO, but we could connect to the it and the imaging tool was seeing the cRIO
Unread 01-02-2014, 13:33
JML's Avatar
JML JML is offline
Jlyon
AKA: Jlyon
FRC #3044 (0xBe4)
The Imaging tool is connecting to the crio, and can see the crio as well as the image on it. The imaging tool does not, however, see the modules plugged into the cRIO
