Go to Post Seriously, I figured we had until january before we started lawyering things again. - JamesBrown [more]
Unread 30-01-2014, 23:00
Reed501's Avatar
Reed501 Reed501 is offline
Team Captain
AKA: Reed Schrier
FRC #2637 (Phantom Catz)
Reed501 is an unknown quantity at this point
Reversing Drive Controls
I've been looking into a way to press a button and have the Y axis for the driving controls reverse, that way when we turn around to pick up the ball in reverse, we can easily use inverted controls.
If anyone knows a good way to do this, I'd love to hear it.
I don't think RobotDrive->SetInvertedMotor() does what I think it does...
Thanks,
--Reed
Unread 30-01-2014, 23:10
TheNightviz's Avatar
TheNightviz TheNightviz is offline
Driving it like I stole it.
AKA: Parker
TheNightviz is an unknown quantity at this point
Re: Reversing Drive Controls
While I haven't messed around with it myself, you might want to look into having your robot's front based on the field possession instead of the a button. To accomplish this you could base the front based on which way the robot is turned, which would only require a gyro. However if you want to stick with a button switch there shouldn't be any reason you cannot code another version of your drive controls with the values reversed in a way that powers everything backwards, and then assigning that command to as you said the Y button. Which language are your programming in?
-2012 San Diego Regional Winners with 4161 and 3476
-2012 Championship Newton Field Competitors
-2012 Battle at the Border Semi Finalists with 812 and 1622
-2013 San Diego Regional Quarter Finalists with 4014 and 2543
-2013 Inland Empire Quarter Finalists with 1138 and 1422
-2013 Battle at the Border Quarter Finalists with 3341, 3647, and 4160 and Gracious Professionalism Award winners
-2013 Fall Classic Finalists with 696, 1836, and 3309 and Team Spirit Award winners
With FRC team 3255 from 2012 through 2014
Unread 30-01-2014, 23:25
Reed501's Avatar
Team Captain
AKA: Reed Schrier
We're programming in C++, and we're driving with new RobotDrive(Talon*, Talon*) and splitting the motor controllers for dual output. We'd have to set up a different driving system, huh?
Unread 30-01-2014, 23:30
AKA: Parker
Thinking about it I'm sure there are many different ways to accomplish this. If you are looking for something somewhat simple though that's what would come to mind for me. However I am more used to Java for FRC so I could be way off basis on this translating to C++. If I'm thinking about it right though all you would have to do is take a negative value, or positive depending on what drives the robot "forward", and have a copy of your drive method/command that uses the opposite joystick value. With your dual output for the Talons I believe this should work rather well, and it would be easy to map to a on/off button.
Unread 30-01-2014, 23:59
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Perhaps you could have a boolean flag that controls whether to reverse some input values. Simple, effective...PERFECT
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 31-01-2014, 00:15
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
It's actually quite simple. Add a case if the button is pressed, and multiply your joystick inputs by -1. This will reverse what is coming from the joystick.
I'm right 90% of the time, so why worry about the other 3%?
Unread 31-01-2014, 00:47
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
For anyone searching this thread later looking for a labview solution...
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
Unread 31-01-2014, 01:09
I generally advise against having a toggle function for a driver input. Unless you put some kind of obvious indicator on the robot itself, knowing which side is the front isn't always easy before you start driving. It can cause problems if the robot moves in the direction opposite the driver's intent.
I would suggest instead using a pair of controller buttons, one to select "forward" and the other to select "backward" driving. That way the driver can always select the one he wants, and won't have to do a tentative drive maneuver before possible toggling to the other orientation.
Unread 31-01-2014, 14:20
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
I agree with this. Having user feedback so they driver/operator knows what state everything is in without having to remember it themselves is always the best option.
