Go to Post FIRST is not about building a robot, it's about the experience of it all... - Beth Sweet [more]
Unread 31-01-2014, 09:56
mickztlin mickztlin is offline
Y_SO_CRIO
FRC #2637
Team Role: Electrical
mickztlin can only hope to improve
pic: 2637 Electronics Teaser
Unread 31-01-2014, 10:05
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Re: pic: 2637 Electronics Teaser
One thing my team (as well as others) has done when using the 8 slot crio is ziptie the digital sidecar on top of the unused crio slots.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 31-01-2014, 10:07
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
It looks very neat compared to most teams.
For the highest levels of neatness, here's a few tips:
-Run all wires in columns. So there would be column along the PD board, which makes a right turn to the plywood bridge, goes across, makes a right turn and then down the alley of talons. Face all of the talons with either power on the inside (so the center column in a 2x3 grid of talons has power in, and the outer columns have power out) or the same direction. Again, right turns around every corner, no cutting corners.
-Run PWMS first, under everything else. They are smaller and easier to manage.We usually run a column down the side of the DSC that goes to the talons or victors.
--Glue the PWM connections, we use silicone but I've heard hot glue works as well.
-Keep the main battery cable as short as possible. If the battery goes where the outline next to the main breaker is, then optimally the red wire between the battery connector and the main breaker is ~3in and the black is ~6in. The short red wire to the PD board is good.
-Strain relieve all wires to the board within a few inches of their device, usually using zip tie pads or holes through the material.
-Zip tie all wire bundles to either a zip tie pad or a hole in the material, every few inches (~6in).
-We have never used fans with our talons, and never had issues. Weight is weight.
-Don't wire over anything, always around.
Kettering Motorsports
Unread 31-01-2014, 13:03
itsjustmrb itsjustmrb is offline
FRC #4063 (TRikzR4kiDz)
itsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to behold
Wasn't there a recent post by an inspector that stated gluing pwm connectors was illegal?
2016 Hub City Regional Winner #3 Seed (3310 & 4301)
2016 Bayou Regional Winner #1 Seed (233 & 4087)
2015 Dallas & Alamo Creativity Award
2015-2016 Hub City Regional Gracious Professionalism
2014 Hub City Regional Engineering Inspiration
2012-2016 Alamo Regional Gracious Professionalism
2016 Bayou Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
Unread 31-01-2014, 13:15
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Keep your speed controllers near your PDB. The shorter your power wires the better.
I'm concerned about where your radio is, since I'm assuming this is going in the belly of your frame. Make sure your radio isn't close to any motors (especially CIMs) and not near any metal in general.
Unread 31-01-2014, 17:51
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Originally Posted by itsjustmrb View Post
Wasn't there a resent post by an inspector that stated gluing pwm connectors was illegal?
And here we go again.
I guess somebody had to say it.
Please, guys, don't let this thread get consumed with the FRC Civil War that is the debate of hot glue on pwms.
Unread 01-02-2014, 03:13
Y_SO_CRIO
FRC #2637
I think Ill hot glue it, and if an inspector comments Ill remove the hot glue it, Im sure he will be fine.
To the victors go the swarf!
Unread 01-02-2014, 03:17
Y_SO_CRIO
FRC #2637
It is actually the far corner of our bot, a little more visible then it was last year, it should be better than last year and there was nothing wrong with last years placement. thanks for the advice though
also thanks for everyone's input, I can never get over how helpful everyone on Chief Delphi is.
